Home > Help Needed / General Tech Chat > fiberglass front end
ryandalby
Member #: 10141
york (UK)
hi im going to be changing the ftont end of my mini to a retro racer fiberglass front end with 4" wide wheel arches.
so i was wondering if anyone had any good tips on how and where to brase it all also whats the best stuff to use????
Thanks Ryan
Sam
Member #: 1686
Oxford
Brace you mean.
Its normal to bolt bars from the front of the subframe through to the inner wing.
Mine is not braces. I however do have solid subframe and engine mounts.
Id recommend bracing onto the shock mount and no where else.
OMG Robert that's a big one
if you fit a removable front the car should use brace bars these can be bought from places like minispares, the car should not pass an mot without them
ryandalby
Member #: 10141
york (UK)
ok then thanks guys ill be going to mini spares this weekend then.
Thanks Ryan
