| Home > Help Needed / General Tech Chat > Fuel pump circuit | |||||||
![]() 323 Posts Member #: 41 Senior Member |
21st Dec, 2003 at 10:41:36pm
Does anyone have the circuit diagram from an injection cooper, i ask because i have just wired in mine, and i took the live from one of the ignition terminals, i would rather i had some sort of fail safe design in case the car is rolled and the fuel pump continues to pump, i was thinking something like a relay so when the oil pressure drops the switch can un latch the relay and stop the pump, onviously i could run the live from the oil switch as when starting the car there would be no oil pressure at first and hance no supply to the pump, how have you guys wired in yours? A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
21st Dec, 2003 at 10:52:46pm
like this?
AlexF |
22nd Dec, 2003 at 06:04:43pm
yes exactly like that, cheers alex A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
23rd Dec, 2003 at 08:53:34am
I'm going to post a copy of it in our tech section, I'm sure dave won't mind.
AlexF |
23rd Dec, 2003 at 12:49:45pm
yeh good idea, i was going to suggest the same, or put it in the "how to" section, as im sure its a question that will be asked again in the future A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
