Home > Help Needed / General Tech Chat > Extra head stud torx setting ?
Jordanmercer
Member #: 9716
Edenbridge, Kent
Does anyone know the trox setting for the extra head stud you can buy ??
normally 25 ftlb for the small ones, but I always use a normal head stud and do them all to 45
tadge44
Member #: 2500
Buckinghamshire
I do the same, but a bit tighter than 45 ft lbs !
Keep The one above the water pump 25 no matter which stud/bolt is there.
tadge44
Member #: 2500
Buckinghamshire
Why ?
As it distorts the block, as there is not much meat over water pump housing
