| Home > A-Series EFI / Injection > MAF | |||||||
17th Oct, 2012 at 03:58:47pm
Purely for data logging, not for the fueling equation.....
17th Oct, 2012 at 05:51:23pm
if there non gen dont trust there readings in an absolute sence, i fitted a non-genuine one to my old rover 75 and it gave the exact same outputs as a genuine pierburg maf(a common retrofit with an adapter box of tricks). Needless to say this was nowhere near what the genuine bosch one i later purchased was showing for given conditions. guess it dpends on how good your non-gen maf's are though. the one i tried came from Euro car parts. and as a benefit of the doubt i bought another later for another car and had the same issues which were resolved with a genuine bosch sensor. if you can get someone with a flow bench to confirm the absolute readings fair play, but if its just to compare between one known car and an unknown then the absolute readings shouldnt matter turbo 16v k-series 11.9@118.9 :)
17th Oct, 2012 at 05:53:57pm
Good idea. What you need is a mad scientist with a cobbled together flowbench to calibrate it for you. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Oct, 2012 at 06:01:38pm
Depends on the flowbench and how that is calibrated in the first place.
17th Oct, 2012 at 06:32:30pm
Just for data logging, as per the first line of my post :)
17th Oct, 2012 at 06:46:38pm
rod, unless its genuine bosch i wouldnt trust the voltage Vs Airflow curve. To compare before and after modifications would be fine but as an absolute reading i would take it with a pinch of salt unless you can confirm with some calibrated equipment. Hope you dont think im being an arse, just had a few eye opening expereinces. Tbo a manometer, vacuum cleaner and thermometer would get you there lol turbo 16v k-series 11.9@118.9 :)
17th Oct, 2012 at 06:59:11pm
The required level of accuracy depends what you are ging to do with the data. If you are plotting air flow on compressor maps, then I would not get too hung up on it. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Oct, 2012 at 07:24:23pm
On 17th Oct, 2012 evolotion said:
rod, unless its genuine bosch i wouldnt trust the voltage Vs Airflow curve. To compare before and after modifications would be fine but as an absolute reading i would take it with a pinch of salt unless you can confirm with some calibrated equipment. Hope you dont think im being an arse, just had a few eye opening expereinces. Tbo a manometer, vacuum cleaner and thermometer would get you there lol Denis, Point taken - the Bosch table quotes voltage to four decimal places.... I doubt if eBay are quite so accurate. Vacuum cleaners, industrial fans, manometers will, however, be the last resort :) It's really an experiment to try and confirm the other EFi data. If we get broad correlation, good. If not we go back and re-consider. A bit like rolling roads I guess
17th Oct, 2012 at 07:51:52pm
No worries, like i say i have had three aftermarket maf's now that were so far out of spec the car ran notably worse, were talking +- 100cfm according to live data on the one i had to measure to prove to ECP it wasn't fit for purpose. it was particularly bad tbf the other two the car just didnt feel quite right. looking forward to the results if you share lol Iv always wanted to use an old MAF to measure blowby to see if it could be used to extrapolate cylinder pressure. turbo 16v k-series 11.9@118.9 :)
17th Oct, 2012 at 08:45:10pm
So, are you trying to verify the AFR from actual air and fuel measurement?
17th Oct, 2012 at 08:55:28pm
be very interesting to know the deviation though! and would also allow for more accurate simulations of a current engine spec. turbo 16v k-series 11.9@118.9 :)
18th Oct, 2012 at 07:33:55am
On 17th Oct, 2012 Paul S said:
So, are you trying to verify the AFR from actual air and fuel measurement? Given that the A-Series does not conform to accepted optimum AFRs, that's a bit idealistic isn't it? No, sticking with the widebands for that especially as I have a third one after the turbo for verification, but... On 17th Oct, 2012 evolotion said:
be very interesting to know the deviation though! and would also allow for more accurate simulations of a current engine spec. It's the latter bit really.... There has been lots of discussion about what VE and BSFC the A-Series actually runs (a lot of it by yourself Paul). An accurate measurement of mass air flow is one more tool to answer those questions. So, contrary to what I said last night Denis, I think I will rig up a venturi/manometer and calibrate it - the calibration curve available in MS2/3 is pretty generic and is taking a fair bit of work to manipulate it to match the supposed curve for this model so I may as well manipulate it to exactly the right curve instead of an expected right one. I wonder how many kg/hr an average vacuum cleaner can pull..... :) Edited by Rod S on 18th Oct, 2012. Schrödinger's cat - so which one am I ??? |
18th Oct, 2012 at 08:43:12pm
I suspect you picked up on my error of the units in my previous post, realised i had it wrong when i woke up this morning (youd think i had better things to think about) cannot remember the actual units off hand but was approx a .5v deviation in the analogue output, so im glad your checking the calibration, you could very easily have good sensors w.r.t the bosch data-sheet but not worth the risk if you want to stand by your results :) turbo 16v k-series 11.9@118.9 :)
18th Oct, 2012 at 09:07:09pm
On 18th Oct, 2012 evolotion said:
I suspect you picked up on my error of the units in my previous post, realised i had it wrong when i woke up this morning (youd think i had better things to think about) cannot remember the actual units off hand but was approx a .5v deviation in the analogue output, so im glad your checking the calibration, you could very easily have good sensors w.r.t the bosch data-sheet but not worth the risk if you want to stand by your results :) Denis, The units are the least of my problems :) It took Jean to tell me I hadn't read the text in the inc file to explain why I wasn't seeing kg/hr..... Graham has tracked down what we believe is the correct part number(s) to actually make a plug to connect this thing up to the IOx and my "local" - local means 25 miles away from where I live in rural Suffolk - VW agent should have the parts in for me 9am tommorow. Then the fun should begin. :) Vacuum cleaners on standby..... Schrödinger's cat - so which one am I ??? |
18th Oct, 2012 at 09:21:17pm
Sounds like fun :)
Edited by jbelanger on 18th Oct, 2012. |
18th Oct, 2012 at 09:57:54pm
On 18th Oct, 2012 jbelanger said:
So we'll need pictures or a video of the setup. Jean, that should be no problem... I have this new (expensive) phone that takes pictures, videos, thousands of other worthless apps (that all work fine) but after 4 days of owning it I still can't actually phone anyone....... Hopefully the right connector should be in a VW dealer for me to collect tommorow morning. Schrödinger's cat - so which one am I ??? |
19th Oct, 2012 at 06:33:20am
happy to help if i can rod . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Oct, 2012 at 07:24:06am
I've been looking at this for a while, and what concrned me was the lack of any sort of bell mouth on the inlet side of the meter. Mainly it depends where you put it in the inlet tract, but having the air filter clamped right onto it, depending on its construction, might give funny readings.
19th Oct, 2012 at 08:00:17am
Couldn't you bite your tongue a bit and go scrap yard and get a genuine on off a car? just to try ? |
19th Oct, 2012 at 12:09:16pm
Robert,
Edited by Rod S on 19th Oct, 2012. Schrödinger's cat - so which one am I ??? |
19th Oct, 2012 at 12:34:54pm
Rod, looking at a VAG airbox that takes this sort of MAF sensor, there is clearly a bell mouth built into the box itself, as can be seen in this pic
19th Oct, 2012 at 12:40:27pm
Colin, nice pic...
19th Oct, 2012 at 01:05:23pm
Right Colin, I think it probably is doeable.
19th Oct, 2012 at 01:08:13pm
As long as it isnt mounted too close to the turbo, I wouldnt be overly concerned.
19th Oct, 2012 at 02:03:30pm
The lack of a bellmouth on the inlet should not be a particular problem if you calibrate it as an assembly.
