| Home > Help Needed / General Tech Chat > Tubular Manifold | |||||||
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
17th Oct, 2012 at 08:22:45pm
Hi all,
18th Oct, 2012 at 08:45:25am
bump |
18th Oct, 2012 at 08:52:36am
Have a go your self at tacking it up to what your looking for, then take it somewhere to get it welded. I have started posting on Instagram also my name on there is turbomk1golf
18th Oct, 2012 at 09:08:08am
Yeah that what I will probably have to do, the only problem I have got, is that I do not have a exhaust pipe bending tool.
18th Oct, 2012 at 09:16:26am
This is most start.
18th Oct, 2012 at 09:55:51am
Cheers this is a big help, thank you very much for this |
18th Oct, 2012 at 10:00:57am
Not looked at your build on the 16v site for a while.. Did you find out the turbo was going to hang out the front then? |
18th Oct, 2012 at 10:43:16am
Not yet, as I have not had a chance to check it in the car yet.
18th Oct, 2012 at 10:46:10am
you need to do some CAD (Cardboard Aided Design). On 11th Feb, 2015 robert said:
18th Oct, 2012 at 10:47:42am
On 18th Oct, 2012 apbellamy said:
you need to do some CAD (Cardboard Aided Design). Lots of loo roll mate I have started posting on Instagram also my name on there is turbomk1golf
18th Oct, 2012 at 10:49:30am
Thata actually a good idea, will be a while to get enought loo rolls though, lol |
18th Oct, 2012 at 10:53:21am
Dont start hanging about in PC's to get them, as people may start chatting :$ I have started posting on Instagram also my name on there is turbomk1golf
18th Oct, 2012 at 10:55:13am
Just found some on ebay, just ordered them, so should be with me by the weekend |
18th Oct, 2012 at 11:10:31am
Yep. Fasten your turbo above the gearbox somehow, then you can make as many runners as you like without ruining expensive tubing.
18th Oct, 2012 at 11:58:19am
Thanks alot for that, I have drawn out a idea of how I want the tubing to be, but I was think more on the lines of 4-1, instead of 4-2 and then 2-1, but as I am new to the turbo scene this may be a better option for the turbo.
18th Oct, 2012 at 12:01:09pm
As long as it's near the turbo then it will be fine. I would still put one in your exhaust under the engine or as it goes into the tunnel to allow the engine to move. On 11th Feb, 2015 robert said:
18th Oct, 2012 at 12:49:52pm
Why not just buy this?
18th Oct, 2012 at 12:58:41pm
Would this fit the 1.6 8v head, as this states its for 2.0 8v.
18th Oct, 2012 at 01:53:45pm
No it won't fit the head you have. And that will probaly hit the engine mount.. You could probably rotate the flange a bit but then I'm 99% sure the turbo will hang out the front of the car.
160 Posts Member #: 1085 Advanced Member Netherlands |
18th Oct, 2012 at 02:02:38pm
Look at performance down pipes for your engine and try and gauge distances between going 4 -2 and 2 -1, then use this as a guide for your fanimold. shouldn't that spell fanny mould then? or am I missing the point as per usual:p 1963 Cooper
18th Oct, 2012 at 02:14:22pm
Yeah I have rotated the flange, but not sure if this will stick out, but if I go with route of the turbo over the gearbox, then I will try and run the downpipe from the back of the gearbox.
18th Oct, 2012 at 02:58:10pm
JUst found out from a member on the mini 16v forum, that has done a NA conversion in the clubby front with a 2.0 8v, but overall same size.
18th Oct, 2012 at 04:25:31pm
Look at performance down pipes for your engine and try and gauge distances between going 4 -2 and 2 -1, then use this as a guide for your fanimold. shouldn't that spell fanny mould then? or am I missing the point as per usual:p Its a play on words. I'm sure people do this in other languages too? FaniMold as in ManiFold. By swapping round the M with the F, the resultant word is a crude example of sexual inuendo. On 26th Oct, 2004 TurboDave16v said:
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
18th Oct, 2012 at 06:22:13pm
Have a load of stainless tube and bends from when i was planninga turbo:
I popped my first one out the other day... |
