| Home > For Sale > pre verto ultra lightweight flywheel with pics | |||||||
22nd Oct, 2012 at 07:53:09pm
As above, in used but good condition.
Edited by cossierick on 23rd Oct, 2012. |
![]() 882 Posts Member #: 9774 Post Whore Buckinghamshire |
22nd Oct, 2012 at 08:01:49pm
Do you know what the weight of it is and where it was bought from? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
28 Posts Member #: 10031 Member |
22nd Oct, 2012 at 08:21:08pm
anyway you can use a pre-verto with an A+ or turbo ? |
22nd Oct, 2012 at 08:46:32pm
that came out wrong.....Can you use a pre-verto with an A+ or turbo? |
22nd Oct, 2012 at 08:54:53pm
Depends on the ring gear on the flywheel, and whether your current clutch is pre-verto, also what starter you have.
22nd Oct, 2012 at 08:54:55pm
double post.. Edited by Mike-998 on 22nd Oct, 2012. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
22nd Oct, 2012 at 09:06:50pm
i need a new clutch plate anyway...i have both types of starter...so is a pressure plate, ring gear and longer clutch arm all that i would need?
22nd Oct, 2012 at 09:16:20pm
i have a light steel backplate davey Crystal Sound Audio said:
23rd Oct, 2012 at 07:54:15pm
pics added
26th Oct, 2012 at 08:03:26pm
On 22nd Oct, 2012 Mike-998 said:
Do you know what the weight of it is and where it was bought from? Sorry i dont no either of the above. I can weigh it if it helps. rick |
28th Oct, 2012 at 12:46:32pm
Sunday bump |
