Home > Technical Chat > Tyres rolling radius
Whats the diameter of 165/70/10, 165/6512 and 175/50/13
jakejakejake1
Member #: 10010
Northants
According to the maths:
about 48.5cm for 165/70/10
51.9cm for 165/65/12
and 50.5cm for 175/50/13
But you may get more accurate answers by getting someone to actually measure their tyres.
best thing is to go from revolutions per mile. (taken from calvers list
165/70/10 1078.47
165/60/12 1047.27
175/50/13 1058.82
divide metres in a mile by the above to get the circumference of the wheel to give....
165/70/10 1.4922 metres
165/60/12 1.5367
175/50/13 1.5199
the divide by pi for the diameter,
165/70/10 47.498cm
165/60/12 48.915
175/50/13 48.379cm
165/70/10 1078.47
165/60/12 1047.27
175/50/13 1058.82
165/60/12 1.5367
175/50/13 1.5199
165/70/10 47.498cm
165/60/12 48.915
175/50/13 48.379cm
http://www.1010tires.com/tiresizecalculator.asp
what exactly are you after? The tyres rolling radius is smaller than the tyres radius.
If you are trying to accuratey work out revolutions per mile for the speedo, you need to use the rolling radius. If its just to work out if fat tyres will fit, then the tyre radius will be fine
rolling radius for looking at gearbox ratios
mine worked out at 19.33 mph/1000 at avon over the line at 112 mph .
topcat
Member #: 9408
Tiptree, Essex
Is the rolling radius less than the actual radius because of the deformation of a tyre with weight on it?
www.topcatcustom.co.uk
Exactamondo
