| Home > General Chat > 998 grarbox or 1275 gearbox | |||||||
![]() 45 Posts Member #: 10141 Member york (UK) |
23rd Oct, 2012 at 08:47:31pm
hi guys
23rd Oct, 2012 at 08:49:50pm
yes, they are the same. On 7th Oct, 2010 5haneJ said:
23rd Oct, 2012 at 09:35:44pm
so they just fit straight out no modification |
23rd Oct, 2012 at 09:51:42pm
Yes! The final drive may? Be higher on the 1275 count the teeth on the differential the big gear and the small gear the pinion gear see it they are the same ? Doesent matter though if you aren't bothered
23rd Oct, 2012 at 10:31:35pm
ok thanks again guys |
24th Oct, 2012 at 08:29:16am
first gear might be different on the 998, but it won't make much difference. On 11th Feb, 2015 robert said:
24th Oct, 2012 at 11:10:08pm
what do you mean different |
24th Oct, 2012 at 11:46:29pm
Don't worry about it.... if your not in to tuning circles your fine!
25th Oct, 2012 at 10:44:49am
slightly different ratios, you probably won't even notice. On 11th Feb, 2015 robert said:
25th Oct, 2012 at 11:32:55am
The 1.3 hle metro had a wide ratio box with a 2.95 final drive identifiable by the double grooves in the tops of the gears.
