Home > Help Needed / General Tech Chat > Carb Questions
Chalkie
Member #: 9764
Northamptonshire.
Hey guys
I got a HIF 38 & HIF 44
The 44 is going with the SC engine next year once insurence stops being knobs and charging me the earth. Do I need a spacer on my 38 with a Alloy inlet mainfold?
only one I've got kicking about is my smoothed and bored out HS4 spacer
are they needed or not?
Thanks
Stephen
Always good to have a spacer
Chalkie
Member #: 9764
Northamptonshire.
Are 44 and 38 spacers the same?
Thanks
No, the 44 will have a bigger hole.
Chalkie
Member #: 9764
Northamptonshire.
Would it make a difference if I used a 44 with a 38 carb don't really wanna fork out for 2 spacers?
sorry for dumb ass questions.
t@z
Member #: 452
Chester, UK
course it will
www.twitter.com/lilpinkiy
Chalkie
Member #: 9764
Northamptonshire.
Ah right damn. best add it to the list then thanks guys
eden7842
Member #: 8852
leicestershire
Ive got a 38 spacer about, im guessing your not to far away
Craigie-B
Member #: 9468
Wootton Bassett
What does the spacer actually do?
Chalkie
Member #: 9764
Northamptonshire.
I live Kettering NN16 area northamptonshire how much you want for it?
skolawn
Member #: 69
Coventry
spaces it *wink* away from the manifold so the float chamber on the HIF or Jet on a HS is not right up against the manifold and it suffer from fuel vaporisation due to heat, also for that reason you need to make sure you use an abutment plate It think its called on a which has your locator for accelerator cable on, and also again acts as a heat shield. Spacers help also with heat soak from the manifold into the carb, and for that reason if you can find one of the rarer plastic spacers they are better.
Paul
t@z
Member #: 452
Chester, UK
im kinda thinking maybe a few things....
- limit heat transfer as its plastic (from manifold)
- longer runner length for air/fuel to mix
- excess of plastic lying about in those days
skolawn
Member #: 69
Coventry
any excess 38 ones I am interested in... Katie my daughter does ministox which is standard heads and manifolds etc, so a standard nylon one is better than a standard alloy one, only fractions but in ministox fractions count...
eden7842
Member #: 8852
leicestershire
Its yours if your heading my way mate
Scudy23
Member #: 10087
Very wet south wales
Simon tapped into his to take gauge readings, cant remember what gauges he said they were though.
Chalkie
Member #: 9764
Northamptonshire.
wonder if its boost gauge? or something to how much air fuels going in? duno
t@z
Member #: 452
Chester, UK
you can get ones with take offs on them for boost/MAP readings etc
Chalkie
Member #: 9764
Northamptonshire.
Don't the carb have a take off for the advance on dizzy though? mine has about 6 pipes coming off it no idea what they are all for?
Flame Red
Member #: 6267
That's one from whatever the economical Metro was called, HLE? It had the part throttle lean-off which worked by applying manifold vacuum to the float chamber, I can't remember the details or the science of it. Anyway, that is why there are so many pipes. Perhaps you can find other uses for some of them, but you'll probably end up blanking them off.
Chalkie
Member #: 9764
Northamptonshire.
Well I know ones fuel in and over flow ones for breathes and one for vac but the other 2 i don't know one in the carb face the odd one above the over flow thanks stephen
