Home > Wanted > 1275 engine
welshdan
Member #: 1111
s wales
Im after a 1275 engine. Would consider anything, from bare block with caps to complete unit. Condition unimportant, as long as the block is sound and had matched caps. Im on a fairly tight budget. Please let me know what you have. Cheers,dan
What are you looking at doing with the block?
welshdan
Member #: 1111
s wales
Im getting it overbored to +73.5, new cam bearings, centre strap, 11 stud holes. So a sound block will do. Sent one for machining last week but its porous
I have a lined one sat here buts no good for you then.
welshdan
Member #: 1111
s wales
Thanks for the offer, but unfortunately not...
Linerd block + 0.040" makes 1312 CC. Great offer
EDIT- Never had. A porous Block and machine 100s did he offset bore it? CORRECTLEY. !
Edited by BENROSS on 24th Oct, 2012.
welshdan
Member #: 1111
s wales
Yes, it is a good offer, i ment unfortunately not any good to me as i already have the 1380 pistons. The guy who did the machining has a lot of experience, in machining and building a series engines. I think that he was suprised also. He has done a few offset big overbores on other engines for us in the past without problems. I guess there were bad batches cast from time to time hence occasional blocks fitted with liners from the factory?
Oli
Member #: 1910
Wilts
I've got a pre a + plus block?
welshdan
Member #: 1111
s wales
Sounds good. How much were you looking for?
Oli
Member #: 1910
Wilts
£50?
It has been over bored before, but no idea to what, about 1310 I think?
Oli
Member #: 1910
Wilts
Infact I'll go and measure the bore as well as I can later :)
i have a sound block i am sure its standard bore though so might be a waste
