| Home > Help Needed / General Tech Chat > what are these for? cooling/oil | |||||||
62 Posts Member #: 10154 Advanced Member Taunton, somerset |
25th Oct, 2012 at 09:21:10pm
25th Oct, 2012 at 09:23:01pm
25th Oct, 2012 at 09:26:15pm
the connection in the top pic is the oil drain, it plumbs into the fuel pump hole in the back of the block.
25th Oct, 2012 at 09:33:58pm
Thanks for your help |
26th Oct, 2012 at 10:48:59am
you need to rotate the centre core aswell the bolt from the second pic should be ontop of the turbo when it is bolted up to the engine Yes i moved to the darkside |
26th Oct, 2012 at 11:12:38am
Thanks Brett
26th Oct, 2012 at 04:39:03pm
Have you the drain adapter which fits to the back of block to connect the Turbo drain to with a hose?
28th Oct, 2012 at 06:37:42pm
no i havent, was planning on making one up, unless i can pick one up cheap.
28th Oct, 2012 at 07:00:54pm
DSN classics sell them in there retro sport range. On 11th Feb, 2015 robert said:
