Home > Help Needed / General Tech Chat > Leaning out around 2.5k
Craigie-B
Member #: 9468
Wootton Bassett
Hello guys
So got the car back together and working, now when I rev to about 2k it leans right out and then if you pull the choke out and it gets past this bit fine and its fine after that.
I have fully rebuilt the carb but I did have this issue before I bought and installed a full rebuild kit
Pleassseee give me some ideas of where to look guys *smiley*
Craig
Rolling road!
Craigie-B
Member #: 9468
Wootton Bassett
Its still doing it after rolling road! Neil said I had to run it in before taking back
Cars undriveable atm
Edited by Craigie-B on 27th Oct, 2012.
Damper oil in the carb? If so, what have you got in? Something a little thicker may help.
I agree with AP. I'd try heavier oil firstly.
Craigie-B
Member #: 9468
Wootton Bassett
Would 10/40 mineral oil be okay?
What's in there now?
Craigie-B
Member #: 9468
Wootton Bassett
3 in 1 oil
TOO THIN!!!!
try 20/50
Craigie-B
Member #: 9468
Wootton Bassett
Put 10/40 in as thats all ive got and made no difference at all.
Cars still burning oil aswell
Really just dont know what to do with it now *oh well*
Block the part throttle lean off pipe.
Craigie-B
Member #: 9468
Wootton Bassett
Got it running better, my dad played around with some of the screws on the carb its driveable now and can run it in then get it down to slark again for final tuning.
Oil burning is alot better since changing the oil return however it might be a case of turbo oil seals being buggered as I know the turbo was sat for about 2 year before I used it
Craigie-B
Member #: 9468
Wootton Bassett
The only pipe I havnt blocked off on the carb is the fuel in *oh well*
Craigie-B
Member #: 9468
Wootton Bassett
