Home > Help Needed / General Tech Chat > weight
t3gav
Member #: 229
Gavin@minispares.com
kent
just continuing stripping more weight off me car but was wondering if its all gonna be pointless if i put a full cage in there, does anybody know how much they weigh roughly. was gonna start buying all carbon bits soon and maybe a beam axle for the rear has anybody done a weight list comparison for the major parts, i think its mainly my wheels which are quite heavy (8*13's) am gonna get some 7x10's hopefully as this should sort the handling as well, grateful for any help
my mini has a full miglia cage, it comes in at around 650kgs that includes my body weight
Edited by Jimster on 12th Jun, 2005.
MaltaMini
Member #: 510
Malta
The cage helps in keeping the body rigid - you gain more in handling than you lose in its weight. Minis can handle badly if you remove weight from the back - all the Minis in Malta which I know and have the rear bar in place of the rear subframe are extremely tail-happy in tight corners... Dont lighten the car too much... rigidity is much more important, for cornering as well as for your own safety.
I donated, but somehow didn't get the label! :(
I'm confident that mine is more rigid than a standard mini.
MaltaMini
Member #: 510
Malta
JEEEEEZ!!!! No can't go that far! Rear has to be trimmed and has to hold all the ICE!!! :d
but for a serious racer, this sure looks the business
The correct tubing helps keep the weight down aswell - not the scaffold spec tubes of yesteryear!
lol i think my weight is more of an issue than the cars
i had to get a new cobra imola in wide version as ive put on so much weight since my bike accident combination of to many ginsters and no excercise
my beam, alloy arms and hubs weighed 20kgs less than a std subframe radius arms and hubs
i removed over 10kgs of that sound proofing crap off the floor
andeh
Member #: 97
Near Daventry, midlands
theres a lot of rubbish going round on weights, does anyone actually know how much your average city (curbweight) would be. I dont trust the haynes book values and have not other references for weights?
Jase
Member #: 349
Lutterworth
I am probably wrong but i estimated that a bogo standard old mayfair would weigh in around 740-800kg
tells you in the haynes manual somewhere
