| Home > Help Needed / General Tech Chat > Limited Slip Diff - Will it Help? | |||||||
134 Posts Member #: 9579 Advanced Member Tadley, North Hampshire |
27th Oct, 2012 at 11:09:19am
So, having mullered my gearbox at a recent track day, I'm formulating a plan. Most of this morning's research has been about gear ratios, which I'm going to have some fun with spreadsheets and the output from my last rr session. This topic however is about LSDs.
My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
27th Oct, 2012 at 11:34:21am
Before going lsd i would sort the suspension out and get it all tracked and setup properly, that willdo more good. Order some adjustable bottom arms and tie bars, i would go rose jointed but that up to ou and what you want to spend. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
27th Oct, 2012 at 05:18:52pm
If you think a normal diff is scary in the wet then an LSD or ATB is probably not for you. It will produce a better lap time but will need more skill and brave pills to get there. |
27th Oct, 2012 at 05:37:51pm
The best single improvement i did for mine handling wise was have it corner weighted almost removed torque steer and although i have other suspension mods and sits 1 inch off the ground witch is not ideal i can push it round corners and not worry
Yes i moved to the darkside |
27th Oct, 2012 at 05:40:38pm
yep good setup is imerative, and removinng as much rubber as possible from the linkages IMO.
27th Oct, 2012 at 05:42:20pm
Mate if you are looking I have a 4 pin diff spare, It needs a rebuild but if you are looking, I am sure we could come to some sort of a deal.
27th Oct, 2012 at 06:03:18pm
A quaife atb is the middle of the road diff , ideal for the road and odd track days.
28th Oct, 2012 at 08:28:26pm
Cheers guys, glad I asked. Will probably stick with a X-pin for the rebuild and do those suspension upgrades and setup instead. LSD clearly something for the longer term! My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
. In the wet quite frankly it was completely terrifying. Not so much in the bends, but in the wet at high speed on the straight stuff it was all over the road and I just had to slow down. In fact this was the point at which my gearbox decided to strip some teeth.
