Home > Help Needed / General Tech Chat > Camshaft help
mossy2a
Member #: 9751
Derbyshire
Gents,
I bought a used Kent 266 cam for my turbo engine. I have cleaned and inspected it to do d it's got an offset key in it, I think it has 4 degrees stamped on it.
Is there any advantages from keeping this installed or shall I put a standard one in??
David
Fit it to your engine and measure the timing. If it's correct for what you want, keep it. If not, change it for one that gives you the correct timing.
The 266 camshaft is timed in at 106 so in
short! !!!! with my experience just install it with that offset key and your away, with a set of New followers, I have tried different. Timing figures but its a pig to drive, not a nice feel to the engine, 106 degrees. Is cock on.
The valve clearances. For that camshaft are all 0.016" if its for Turbo application make the exhaust. Clearences 0.018"
Edited by BENROSS on 28th Oct, 2012.
mossy2a
Member #: 9751
Derbyshire
Cheers chaps, will hopefully have the bottom end built soon.
David
