| Home > Help Needed / General Tech Chat > which makewheel bearings are best ? | |||||||
337 Posts Member #: 9138 Senior Member wolves |
28th Oct, 2012 at 09:58:23pm
whats the best make to buy ? put 2 on the sons now and getting a bit fed up with cheap tack shit in plain white boxes .
28th Oct, 2012 at 10:00:38pm
Timkin,
28th Oct, 2012 at 10:23:35pm
front both sides . torqued to 210nm with a washer then with the taper washer .
28th Oct, 2012 at 10:36:46pm
yeah i agree,
28th Oct, 2012 at 11:14:14pm
On 28th Oct, 2012 Joe C said:
christ! the timkin ones are well pricy now! they were 22quid last time I looked. http://www.minispares.com/product/Classic/...k%20to%20search Not that expensive if you have to replace the cheaper ones twice. Just majke sure that you check for even the slightest bit of play in the bearings when fully done up. If there is the slightest play, it won't matter what bearings you fit, they won't last long. On 26th Oct, 2004 TurboDave16v said:
28th Oct, 2012 at 11:25:18pm
right timkin it is then, cheers all
29th Oct, 2012 at 07:16:50pm
Good god, just totaled up a new set of timkin front and rear wheel bearings and genuine ball joints and its come to £200 quid. Bloody minis! On 7th Oct, 2010 5haneJ said:
29th Oct, 2012 at 07:27:29pm
Glad I bought those new old stock bearings and ball joints at MITP 2010. I could rebuild the front hubs twice for less than £40 all with Gauranteed genuine parts On 26th Oct, 2004 TurboDave16v said:
29th Oct, 2012 at 08:39:43pm
timkin bearings are around £11 each (£22per hub) but im trying to get a deal on 12 bearings from bsl so with seals should be about 26 per hub . if anyone interested in some bearings let me know. they can get the seals also but i need a part number
29th Oct, 2012 at 08:57:11pm
As long as they are the real deal I'm in, but considering the quantities minispares are buying them in at I would question how they are so cheap. On 7th Oct, 2010 5haneJ said:
29th Oct, 2012 at 10:04:55pm
timken* and yeah i agree timken all the way, theyre used timken bearings on steam trains |
