| Home > General Chat > 1380 to 14.. Something | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
29th Oct, 2012 at 04:24:11pm
Hi guys,
29th Oct, 2012 at 04:51:16pm
Cooper s rod, stroker crank, 1430
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
29th Oct, 2012 at 04:55:56pm
plus short pistons. On 28th Aug, 2011 Kean said:
29th Oct, 2012 at 04:58:02pm
29th Oct, 2012 at 05:28:31pm
Andy has a point! 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
29th Oct, 2012 at 05:34:48pm
The crank, rods etc are getting rare and will be expensive if you can find some... On 11th Feb, 2015 robert said:
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
29th Oct, 2012 at 05:48:46pm
Use mg midget conrods Edited by Oli on 29th Oct, 2012. On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
29th Oct, 2012 at 06:36:34pm
for the sake of 50cc I would rather stick with the large journal crank 1380, put a bigger cam in it and rev it harder.
29th Oct, 2012 at 07:04:58pm
On 29th Oct, 2012 apbellamy said:
fook that, stick a turbo on the 1380 ![]() What he said lots of fun to be had! I have started posting on Instagram also my name on there is turbomk1golf
29th Oct, 2012 at 07:35:56pm
Unfortunatly i've just spent a small fortune getting my bike carbs setup and running right so i want to stick with NA for this engine. Looking at building a 998 screaming turbo engine as a side line project.
29th Oct, 2012 at 07:38:34pm
What do you use it for?
29th Oct, 2012 at 07:43:35pm
I don't use it really..... comes out now and again during the summer for a good old fashion good time.
29th Oct, 2012 at 07:46:01pm
You will have to get the carbs set up again it you stroke the engine and the compression ratio changes??? |
29th Oct, 2012 at 07:55:50pm
How good is the head, that will obviously have a bearing on how mad you can go?
29th Oct, 2012 at 07:56:13pm
true. thinking stroking might not be the way to go. (must go for a brain clean, that just sounds rude) |
30th Oct, 2012 at 07:17:12am
Long strokes don't like revs, I'd say of it a 296 scatter cam and maybe improve t he head a bit which will about the same cost as stroking it and you'll get more gain I seriously doubt it! |
30th Oct, 2012 at 08:32:52pm
Right plan is, Stick to 1380cc, head is already large valve something like 37,31 can't remember exactly, swap the cam for a sw10 or sw5. swap flywheel for a preverto ultra light thing with a uprated diapham. replace all the bearings, oil pump etc
1391 Posts Member #: 1686 Post Whore Oxford |
30th Oct, 2012 at 08:35:54pm
The issue you have is. Anything you do will affect the tuning of those carbs.
OMG Robert that's a big one |
30th Oct, 2012 at 08:39:36pm
yep, but now i have the jetkit installed and already having a base setup a little tune up to match the new mods won't be too hard. |
30th Oct, 2012 at 08:56:51pm
SW5 will be too tame so forget that one!
