Home > Help Needed / General Tech Chat > carb rebuild , dashpot question
turbochargedstu
Member #: 908
gateshead
i have tried to look on the search but cant find anything. i have just rebuilt my hif44 n/a carb using a turbo rebuild kit and used mr fentons excellent how to. now, when it comes to putting the dashpot back on the carb body, it says to fit the big seal between the 2. how the hell do i do that when there isnt a groove for it to sit in. is it just for the turbo carbs and will it matter if i havent got it?
cheers.
stu
balls to the blower!!!
pinkyandnobrain
Member #: 2588
Pretoria South Africa
You'll have to machine a groove into the carb body. Turbo carbs have the groove, NA's dont.
"Try to take over the world!"
Scudy23
Member #: 10087
Very wet south wales
Can it not just be sealed with something ?
pinkyandnobrain
Member #: 2588
I wacked the dash-pot in the lathe and cut a groove in the bottom edge where it rests against the carb body, works ok but the seal falls out every now and then when I remove the dash-pot.
You could try some kind of sealer but I dunno if it will hold with all the fuel passing around that area.
