| Home > Help Needed / General Tech Chat > So now what? Hmmmmmmm.... | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
31st Oct, 2012 at 12:42:51am
Hi all.. apart from introducing myself this is my 1st post, apologies in advance if it's in the wrong place or if it's been asked before. I have done some searches but can't find what I'm looking for.
319 Posts Member #: 1742 Senior Member essex |
31st Oct, 2012 at 06:19:06am
hiya there are a few tell tales. If you can take a few pics of the engine. Also clean up the engine number if it has one it will be on the top of the block above where the alternator goes. Let up know the numbers and we should be able to tell you what at least it started out. James My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
31st Oct, 2012 at 08:40:25am
As a minimum I would split the engine from the gearbox and pop of the main and big end caps. Then replace the bearings and if needs be grind the crank. Also pop a new oil pump in while you are there. This should give you good oil pressure when it goes back together.
31st Oct, 2012 at 12:20:15pm
there are a few simple easy checks you can do,
31st Oct, 2012 at 01:33:38pm
Ok guys, thanks for the replies! Regarding the engine number... It's missing, only the two brass rivets that would hold it in place are there, looks like it has broken off.
31st Oct, 2012 at 01:56:43pm
31st Oct, 2012 at 02:53:40pm
So what about the metro turbos? |
31st Oct, 2012 at 02:58:24pm
Metro turbo was an A+ 1275 engine so as Andy says all were red apart from the later MPI engines which are a different block. Edited by Tom Fenton on 31st Oct, 2012.
31st Oct, 2012 at 03:02:49pm
Ah I see... It all becomes clear. So my block should be red, or signs of it. |
31st Oct, 2012 at 03:40:52pm
yep, its probably under the blue as the red is sooooo hard to get off. On 28th Aug, 2011 Kean said:
31st Oct, 2012 at 03:49:08pm
So am I correct in thinking that my engine is the same bore as a 1275.. With a turbo? I thought it was slightly bigger?
31st Oct, 2012 at 03:53:33pm
yep, same bore, unles its been rebored,
31st Oct, 2012 at 03:54:22pm
On 31st Oct, 2012 evad1980 said:
Do excuse the noob questions please! I gotta start somewhere... Yes of course, please try the "Beginners Tech" forum section and do some reading up. Edited by Tom Fenton on 31st Oct, 2012.
31st Oct, 2012 at 04:21:41pm
Will do.. Thanks! I'll check out the exhaust valves tomorrow!! |
31st Oct, 2012 at 04:25:09pm
yep, stems on a genuine turbo head are fatter on the exhaust, easy to see with the rocker cover off,
31st Oct, 2012 at 06:35:33pm
This is also a good starting point:
1st Nov, 2012 at 02:17:47pm
Nice.. some good info.. cheers!! |
