| Home > General Chat > Making a distributor drive gear- not mini related | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
31st Oct, 2012 at 09:08:24pm
I've got a 1932 straight 8 engine, that I have finally managed to find a distributor for which was hard enough (engine was missing it when I got it), however I do not have a drive gear for it. It is traditional in that it meshes with the cam, and drives both the dissy and the oil pump, I reckon it's approx 40mm diameter, and I only have the cam to go off for dims etc.
www.topcatcustom.co.uk |
31st Oct, 2012 at 09:27:54pm
just buy it, you certainly wont get one made for that kind of money
1st Nov, 2012 at 10:19:02am
What I was thinking, just pissed that someone bothered to nick it when it's not even part of the dissy!
3rd Nov, 2012 at 07:10:58am
For what it's worth re. the dimensions, if it's a 90 degree skew gear (with teeth at 45 degrees) it should be identical to the one on the cam because of the 1:1 speed ratio between cam and dizzy.
Edited by Rod S on 3rd Nov, 2012. Schrödinger's cat - so which one am I ??? |
3rd Nov, 2012 at 09:20:46pm
Your between a rock and a hard place sorry to say
4th Nov, 2012 at 09:27:16am
Buy it before someone else does or he changes his mind. then you'll kick yourself for not buying it.
4th Nov, 2012 at 10:04:18pm
What engine is this for? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
5th Nov, 2012 at 02:00:40pm
Yeah I guess the only other option I have is to make one out of a spare cam- but never seen one of those for sale either!
5th Nov, 2012 at 08:01:22pm
One dizzy with 16 leads ? feck lol That's gotta be some size !
6th Nov, 2012 at 08:31:06am
Stevie it has 2 condensers, two sets of points, and a twin rotor arm too! (Luckily the cap is numbered so you don't have to work out what leads go where!) www.topcatcustom.co.uk |
