Home > Help Needed / General Tech Chat > Can someone help me out please.
Scudy23
Member #: 10087
Very wet south wales
Firstly the carb rebuild lol again, do these pictures look right ? I have however taken the throttle lever back off due to it hitting the manifold so im assuming the throttle lever has to go on the other side now ?
This is the side the throttle needs to go on
Side which throttle was on
This is what i got left
Secondly, the cylinder head i have is a 12g295 ..... Are there any sign from these pics that is an unleaded head ?
Scud
Craigie-B
Member #: 9468
Wootton Bassett
Oddly enough mines on the opposite side to yours and would be interested to see if anyone thinks it makes a difference
Scudy23
Member #: 10087
As it is in the pic there wont fit, i trial fitted the manifold and the throttle lever had to come off, do you have any pics of yours craig ?
Im assuming the standard hif44 carb has the lever on the opposite side to the hif44 turbo carb.
First issue is, that is not a turbo SU.
This is
And what's going on with those huge valve guides ?
Scudy23
Member #: 10087
Thats correct its a normal hif44 but im yet to block off bits i need to etc
What you mean by huge valve guides ? As u can see im not clued up on valve guides lol they do not look normal to you do they ? I was sold it as be unleaded, does that involve bigger valve guides.
This is
jlay
Member #: 1742
essex
there are different turbo carbs that had the throttle levers different sides i think its the earlier ones that have both the same side. They use a different abuntment plate and the cutout in the manifolds were different. It foremu really matter what you use as long as you make enough clearance for everything.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
tadge44
Member #: 2500
Buckinghamshire
If it is any help, I have had to "ease" the inlet manfold to allow the throttle to open and close - just a little with an angle grinder.
The issue with your throttle cam is that it is huge. Look at it compared to the turbo one. They are totally different.
If you can find the correct or a smaller throttle cam, you should be fine.
The guides just look very unfinished. Big and square inside the port.
Maybe it's just been that long since I seen a standard one....
Scudy23
Member #: 10087
This turbo stuff is really starting to get up my nose now tbh, everything i seem to buy has its own problems.
Scud
If simple stuff like this is bothering you, I'd suggest you go and buy all the standard metro turbo bits and just bolt it together.
This really isn't an issue with "turbo stuff".
Mate what you have to do is slow down make a plan, Think about a part and what you have to do to make it work, Ie carb, then have a read up on it! as its been done before! and then buy what you need.
Remember every day's a school days, If i worked on my car as much as i sit on here reading it would be done in a week.
simon.
Scudy23
Member #: 10087
Ok fair enough, like many others im learning as i go, i have a read buy what others have used then turns out BOOM!!!! The fu fu valves shot.
Now im on the search for the other type throttle cam lol or a new carb alltogether
Scudy23
Member #: 10087
Thanks for the sound advice Simon
Scud
simon.
Mate I have been where you are so many times thats all. I have a book and when I am on here at night I wright stuff down in it. Also I put all my info in it so then I can look back at it.
Simon
tadge44
Member #: 2500
Buckinghamshire
I managed to make it work with that throttle cam, so you can too.
Scudy23
Member #: 10087
On which side ?
