Home > Help Needed / General Tech Chat > What else do I need?
kappa
Member #: 9854
Hounslow, Middlesex
Hi all I am in the process of building a turbo conversion?
Now this is the list of things I have purchased so far, what else will I need?
1. Turbo head, with bigger 24cc chambers cut out.
2. Mirage Manifold
3. Hiff44 turbo carb
4. Turbo plenum
5. Intercooler
6. Actuator
This is a list of things I have already. I am looking to turbo my original 1330cc engine, but to run low boost to start with, then I will change my pistons and conrods for forged one to up the boost.
Will I need anything else to complete this set up for a low boost conversion?
In regards to my gearbox, will I be able to run the standard box for now and upgrade later and can run this set up with the standard electronic dizzy to start with or will this need to be upgraded as well?
Bobby
kappa
Member #: 9854
Hounslow, Middlesex
Sorry forgot to mention the main thing, the turbo, this is:
1. T2/GT15 hybrid with a 360* thrust bearing in there.
Bobby
Mike-998
Member #: 9774
Buckinghamshire
You'll need to modify the fueling with a fuel pressure regulator and all necesary fittings etc
A 4 pin diff is a minimum gearbox wise really
All the info you need parts wise can be found on www.turbo-mini.com
kappa
Member #: 9854
Hounslow, Middlesex
Thanks a lot Mike-998
What cc pistons does the 1330 have in it?
kappa
Member #: 9854
Hounslow, Middlesex
I am not too, sure as i bought the engine complete and did not build it.
I have got the head off at the moment, is there a way of working it out.
But when i did do a compression test on the head it did read 120psi to 130psi
welshdan
Member #: 1111
s wales
You might be able to get a very rough measure of the piston dish by using oil and a syringe...though i believe most aftermarket a series pistons have around 6-7 cc in the crown. It would also be useful to obtain the deck height at tdc to see if any cc can be found there
120-130psi quite a veriety and all quite low on pressure, they idealy should be all very similar psi on test 10psi seems quite a differance to me. I would have the head off and check everything, for the sake of a few gaskets could save you alot of money.
kappa
Member #: 9854
Hounslow, Middlesex
How do I measure the cc in the piston with a syringe?
Do I just put oil in the dish and take it out with a syringe and what ever it measure thats what the cc should be?
Sorry, typing one fingered due to being pinned down by a cat!
Set piston at tdc.
get a piece of perspex larger than the cylinder and drill 2 small holes in it. ring land volume and piston to deck height all count, so it needs to sit on the deck, not just the top of the piston.
fill with liquid from a syringe, take note of quantity, making sure none escapes,
Edited by minimole23 on 4th Nov, 2012.
wng691s clubby
Member #: 9252
Cleethorpes
how big is your cat??
Done now needs redoing lol
Not that large, but didn't have the heart to move her to try to type with 2 hands!
kappa
Member #: 9854
Hounslow, Middlesex
I was looking at Force Racing website earlier, and noticed they do machine work to pistons.
Is it a good thing to get my pistons machined so I get a bigger CC out of the dish to reduce the compression ratio.
If so what CC is it good to get the pistons machined too, with my pistons?
All help is appreciated.
Bobby
Mike-998
Member #: 9774
Buckinghamshire
well that depends on what your compression ratio is at the moment, have you measured it?
Edited by Mike-998 on 5th Nov, 2012.
kappa
Member #: 9854
Hounslow, Middlesex
when I measured it, it was reading 126 psi on two cylinder and 131 psi on the other two cylinders
Mike-998
Member #: 9774
Buckinghamshire
thats your compression generated by the upsweep of the piston.
Compression ratio is the ratio of the volume of the combustion chamber with the pistons at BDC to the volume of the combustion chamber at top dead centre. There are plenty of guides around on how to calculate it.
t@z
Member #: 452
Chester, UK
Bobby, your going to have to measure your pistons/deck volume as i mentioned. There are no shortcuts sadly and people will struggle to help you without it
here's a link to that file i mentioned the other day. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=498635
you could always try and clean the top of the pistons to see if it has any numbers however your still going to need to measure your deck volume.
www.twitter.com/lilpinkiy
kappa
Member #: 9854
Hounslow, Middlesex
Thats great, I tried to have a go at it and its saying I need to remove -11.55cc from my pistons to achieve a 7.5:1 compression.
Is this right?
Mike-998
Member #: 9774
Buckinghamshire
That's a low compression ratio, how much boost are you planning on running? With a CR that low you'll be losing a lot of performance off boost. but if you're set it might be worth looking at getting the head machined out as well? especially if you cant take loads out of the piston
aim for 8.5:1, or 9:1 if your going to run less than 10 psi boost
kappa
Member #: 9854
Hounslow, Middlesex
Oh cool, well I put 8.5:1 its reading I need to take out -4.74 cc out of the piston.
Joe C, you said if I am going to run less than 10psi, but if I wanted to run more PSI, would I go a lower compression?
the std metro turbo was 9.3:1 and ran 7 psi boost, Ive seen 9:1 used at 10psi, and bit higher with a good intercooler,
quite a fre people on her run in the region of 8.5:1 and up to 20 psi (or more!)
its all a bit of a guess really as it depends a lot on fuel, how effective the intercooler is how rich, what the specs of the engine are etc etc.
what I put above is a good guide though,
kappa
Member #: 9854
Hounslow, Middlesex
Ok well that is very helpful, thank you for that
Metro turbo was 9.4:1 *wink*
