Home > Help Needed / General Tech Chat > Quickshifts and Internal Gear linkages.
Is anyone having success with these?
Over the winter I wish to amend my internal linkage to remove play to make it more precise, and shorten the throw. I have added 2 bushes to the selector remote to remove slack there, and also remounted it so there is a single UJ.
I must say I never really got on with my KAD One, as it just felt too tight, even with the linkage in the standard location. I couldn't get it to work at all with the internal linkage, as there wasn't enough degree of movement to take up the 2 uj's worth of fractional movement.
So, those using Quickshifts mounted internally, how have you managed to get it to work? Pictures of the set up are appreciated.
Thanks
James
i spent a good amount of time sorting my gear stick and linkage out, although i never went internal it was worth all the hard work, so much so 1380 rich fell in love with it *hehe!*
i have a KAD copy gearstick and i had to shim the selector housing so it was at the perfect angle to get all gears
