| Home > Help Needed / General Tech Chat > double head gasket | |||||||
28 Posts Member #: 10031 Member |
7th Nov, 2012 at 09:24:29pm
Hi all
7th Nov, 2012 at 09:34:43pm
it can be done, but I'd only recomend it as a temporary measure,
7th Nov, 2012 at 09:44:12pm
dont really want to mess around with the head anymore....it already has 37mm inlet and 29mm exhaust along with porting , polishing and 26cc already seems pretty large....would hate anything to happen to it while getting work done :o |
7th Nov, 2012 at 09:48:16pm
well, as long as its not been skimmed 28cc is a common chamber size,
7th Nov, 2012 at 10:08:57pm
so does 11cc seem about right for the bore chamber? |
7th Nov, 2012 at 10:20:32pm
You'd defintely be better off machining a couple of cc's out of the head and a couple out of the pistons.
7th Nov, 2012 at 10:31:23pm
Its feasible but insane!!!
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
7th Nov, 2012 at 10:49:05pm
Scrap that, just re-read it.
Edited by Alex on 7th Nov, 2012. Metric is for people who can't do fractions. |
7th Nov, 2012 at 11:36:24pm
hmmm....so where to get the extra 3.5 - 4cc from?
7th Nov, 2012 at 11:48:36pm
Remember to check you rocker geo after as your changing the height of the head.... Only buy a small a mount but still worth checking.
8th Nov, 2012 at 12:07:03am
hi gr4h4m
8th Nov, 2012 at 12:41:58am
gr4h4m see what you mean
8th Nov, 2012 at 01:01:41am
I wouldnt use two head gaskets, especially on an fi engine, its asking for trouble. Probably the best way as said is to take a few ccs out of the chambers |
8th Nov, 2012 at 08:19:29am
You can adjust them but thee might foul the holes in the head, or run out of adjustment, the advice I have had is when closed you want the rocker parallel with the surface of the head, with push rod height being wrong they will be nose up or down!
On 8th Nov, 2012 daveydavey said:
gr4h4m see what you mean extra height means the push rods will be short. cant i sort this by doing the rocker tappetts? I run a supercharger and I don't care the TB is on the wrong side.
8th Nov, 2012 at 09:02:09am
This makes no sense, how can altering the thickness of the head affect the rocker alignment in relation to the valve?
On 8th Nov, 2012 gr4h4m said:
You can adjust them but thee might foul the holes in the head, or run out of adjustment, the advice I have had is when closed you want the rocker parallel with the surface of the head, with push rod height being wrong they will be nose up or down! My head had had a lot chopped off so I have to run a 3mm shim to get them back to square, so much so that when I ran 1.5 I ran out of adjustment on the nut. Just some thing to think about, a better solution is to size the piston and head. Next down from than might be a faraday gasket, however they recommend having everything perfectly flat (head and block). Two gaskets is going to be a bodge and will be less reliable than doing it properly. On 8th Nov, 2012 daveydavey said: gr4h4m see what you mean extra height means the push rods will be short. cant i sort this by doing the rocker tappetts? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Nov, 2012 at 09:16:00am
First question should be what level of boost did you intend to run.
![]() 580 Posts Member #: 9580 Post Whore Surrey |
8th Nov, 2012 at 09:58:18am
Having used a de-compression (steel sheet) plate with 2 head gaskets I can recommend not going this way. As a stop gap to buying pistons I had a copper plate machined as a one piece gasket/de-compression plate. 146nannas and holding strong. |
8th Nov, 2012 at 10:04:33am
Decompression plates only work of they are made out of cast iron - the differing expansion rates of the head, block and (cheap) steel plate tears the gaskets. Metric is for people who can't do fractions. |
8th Nov, 2012 at 11:50:20am
Remember that it is the temperature of the air entering the combustion chamber that is the enemy, not the boost.
8th Nov, 2012 at 01:13:52pm
so what would you recommend then Paul? |
8th Nov, 2012 at 01:19:04pm
Depends on your hp target. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Nov, 2012 at 03:00:50pm
lol....lots |
8th Nov, 2012 at 05:44:53pm
In that case i'd be investing in some decent pistons with a larger dish. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Nov, 2012 at 07:13:22pm
On 8th Nov, 2012 wil_h said:
This makes no sense, how can altering the thickness of the head affect the rocker alignment in relation to the valve? It does alter it in relation to the pushrod, i.e. you have to adjust the adjuster. The further out the adjuster the less lift at the valve you get. But the thickness of a head gasket is neither here nor there, assuming it's ok at the moment. The only proper way to compensate for the head being skimmed or raised (in this case) is different length pushrods. Spacers under the rockers are not to compensate for head thiskness or block decking. Rather they are to fix issues of rocker geometry where you have sunken valves, or long or short valve stems. On 8th Nov, 2012 gr4h4m said: You can adjust them but thee might foul the holes in the head, or run out of adjustment, the advice I have had is when closed you want the rocker parallel with the surface of the head, with push rod height being wrong they will be nose up or down! My head had had a lot chopped off so I have to run a 3mm shim to get them back to square, so much so that when I ran 1.5 I ran out of adjustment on the nut. Just some thing to think about, a better solution is to size the piston and head. Next down from than might be a faraday gasket, however they recommend having everything perfectly flat (head and block). Two gaskets is going to be a bodge and will be less reliable than doing it properly. On 8th Nov, 2012 daveydavey said: gr4h4m see what you mean extra height means the push rods will be short. cant i sort this by doing the rocker tappetts? I run a supercharger and I don't care the TB is on the wrong side.
