| Home > Help Needed / General Tech Chat > tubbing arches | |||||||
7th Jun, 2005 at 10:58:08pm
hi i know someone had some really good pics of how to do this but cant find them, my car is gonna be on 10 inch wheels but a road car so is it really worth it i wanna be able to go over speed bumps! |
![]() 48 Posts Member #: 349 Member Lutterworth |
8th Jun, 2005 at 12:12:49am
I am not sure that the cutting the arches is necessary for speed humps but mine grounds the sump and the exhaust over the smallest bump. Have started doing the rear arches on 1 shell and its quite straight forward. |
8th Jun, 2005 at 12:18:55am
not sure if i wrote that right but i didnt mean if i cut them will they hit the floor i meant is it worth it as in i can probably get it low enough without chopping bits for the road if that makes sense |
8th Jun, 2005 at 06:14:08am
No not worth the effort for 10" wheels and road use. You will get it low enough to run into other problems (e.g. sump,exhaust) before you hit the rear arches.
8th Jun, 2005 at 10:32:51am
8th Jun, 2005 at 10:54:01am
cheers mate thought it was your car i looked at |
96 Posts Member #: 251 Advanced Member Nottingham UK |
9th Jun, 2005 at 06:24:48pm
When tubing rear arches do you bend a new lip from the rear quarter or just extend the rear arch out and seam weld it? |
10th Jun, 2005 at 11:23:30pm
always wondered about the rod change how do you modify it? any pics? cheers |
11th Jun, 2005 at 08:13:38am
if you've got the cash KAD do a kit for an internal linkage.....otherwise its a coule of UJ's and some cutting and welding :)....and solid mounting the engine i think On 20th Oct, 2015 Tom Fenton said:
12th Jun, 2005 at 11:19:26am
re tubbing, you bend the rear qaurter to make the lip, and the metal that you add under the arch you bring out to the edge of the lip. There are some pics on my website, bascily bud has it, but you do need to solid mount the engine and subframe. On 15th May, 2009 TurboDave said:
12th Jun, 2005 at 09:21:12pm
uj's? how come the engine has to be solid mounted? |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
12th Jun, 2005 at 09:36:23pm
its because normally the gear selector is on rubber mounts so can move a little when the engine moves stopping it popping out of gear, hence when you solid mount the gear selector you've got to do the engine
12th Jun, 2005 at 09:37:28pm
You don't use the bottom stabiliser bar on the linkage,If it's not solid mounted jumps out of gear with engine rock
12th Jun, 2005 at 10:03:30pm
still ujs huh wtf! why dont people rubber mount the linkage inside the car then? |
12th Jun, 2005 at 10:59:32pm
uj....universal joints......as rod won't bend
12th Jun, 2005 at 11:04:07pm
aha thanks is that what everybody uses, anyone got a pic? |
12th Jun, 2005 at 11:07:56pm
http://www.users.globalnet.co.uk/%7Egraham...4photoprint.jpg
Edited by Dangerous on 12th Jun, 2005.
12th Jun, 2005 at 11:11:48pm
it doesnt work sorry : ( |
12th Jun, 2005 at 11:13:46pm
ok does now cheers, what cars that anyway looks mad! |
