Home > Help Needed / General Tech Chat > Injection fuel sender
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys,
Im running spi tank with the 3 clock setup but fuel guage isnt working,
It worked with standard tank so I want to ask do i need to swap to my old fuel sender for it to work with my clocks as I read somewhere the injection senders may be different?
Yes I tried swapping the wires over, no joy
You could try swapping them, but you have to bend the standard one to match the injection sender. I think I am going to end up doing the same...
Craigie-B
Member #: 9468
Wootton Bassett
I take it my tanks going to leak if i just popped it out with petrol in there?
Yes. If you make a big hole in your petrol tank, petrol will come out of the hole.
mossy2a
Member #: 9751
Derbyshire
Did you just really ask that question??
Have you tried the connections, one of my old minis sender never worked and it turned out to be a dodgy connection, after changing the sender.
Edited by mossy2a on 12th Nov, 2012.
*happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy**happy*
Craigie-B
Member #: 9468
Wootton Bassett
Pmsl
Why am I so dense xD
Yes i tried swapping the plugs over checking it all etc worked perfect before swapping tanks
Johnny
Member #: 6926
Accrington
try plugging one in, out of the tank and get someone to hold it as if it was full and then empty see if the gauge works
Craigie-B
Member #: 9468
Wootton Bassett
okay thanks *happy*, would i just lift the float up
mossy2a
Member #: 9751
Derbyshire
Basically yes, see linky
http://www.youtube.com/watch?v=Zm8E-_yNSK8
