Home > General Chat > elecric fuel pump for r1 project
mercenary62
Member #: 9937
looking for a electric fuel pump for my r1 injection mini project ,must be capable of 170 ish bhp any ideas lads it will also be mounted remotely outside the fuel tank thanks
give em hell
JBE
Member #: 9187
Västerås Sweden
Bosch 044 ?...
Less then 8", is too small...
t@z
Member #: 452
Chester, UK
dude why dont you just get all your questions together and put it in help needed. that way saves multiple question in the wrong place :)
also if you search "electric water pump" theres plenty of info as i recently was reading up on this.
Edited by t@z on 13th Nov, 2012.
www.twitter.com/lilpinkiy
Craigie-B
Member #: 9468
Wootton Bassett
use a mpi fuel tank/pump ??
oli79
Member #: 8480
I will stand corrected but should suffice with the same set up as my z car and indeed what most people seem to fit on any injection bike transplant, generic bosch injection fuel pump(3 bar rings a bell) and get an aftermarket fuel pressure regulator, set that to give the required pressure at the fuel rail which the R1 requires. The reg will have 3 connections fuel in, a return line to the tank and a feed out to the fuel rail, and fitting an inertia switch wouldnt be a bad idea to avoid an upside down fireball type incident.
Oli
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Pretty much any efi pump will be capable of that power level.
What size or fitment do you need ? Internal, external, hose sizes etc ?
044 is a 600hp pump, I would not recommend one for such a low fuel requirement.
Whats wrong with a metro turbo pump? Many oem efi cars have them
mercenary62
Member #: 9937
yeh il be using a metro turbo fuel pump asi are doing them at 40 quid thanks for all the replys guys
give em hell
