| Home > Help Needed / General Tech Chat > Making a turbo manifold | |||||||
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
15th Nov, 2012 at 11:41:06pm
I'm going to be turbo charging my vauxhall engine in my mini, I've seen a few people make log style turbo manifolds, I know a local company that can make my flanges, but where do you get the pipe to make them?
Turbo parts collector at the moment, almost ready. |
16th Nov, 2012 at 12:06:21am
Any decent plumbing type supply place, or stainless/alu stockholders
16th Nov, 2012 at 12:10:48am
oddly...just googled looking for a 3" alloy bend and found this lol
16th Nov, 2012 at 12:13:23am
Ok great, anyone know roughly what sort of bore I should be using, I was thinking 2" ID, its a 1800 16v engine Turbo parts collector at the moment, almost ready. |
336 Posts Member #: 9941 Senior Member Derby |
16th Nov, 2012 at 07:19:41am
places like bss or wolsey pipe centre or crosslings will sell you 2" ID fittings tell them its for welding and ull get it cheap |
16th Nov, 2012 at 08:49:06pm
On 16th Nov, 2012 mini_mad69 said:
Ok great, anyone know roughly what sort of bore I should be using, I was thinking 2" ID, its a 1800 16v engine Depends on the style of manifold. If a full tubular, the you could consider a 2" bore for 8-900hp upwards. Log style like pictured and very short then 2" tubes probably wouldnt hurt. Generally it is more about maintaining heat and gas speeds with turbo manifolds than having large diameters. But for a tubular manifold, even 1.5" OD fine, maybe 1 5/8" if you were pushing hard. Having excessively large tubes will hurt spool which will hurt performance. That's why some makers ( Vauxhall was one ) cast the turbine housing and manifold all in one piece. 9.85 @ 145mph
16th Nov, 2012 at 11:25:53pm
Fantastic, im not going for out and out power yet. Just need to get it running and can then develop it from there with better manfiolds etc. Thanks for the help, this site never seems to fail on technical help. Turbo parts collector at the moment, almost ready. |
17th Nov, 2012 at 06:42:56pm
TBH, even the most horrific and ugly manifolds will still allow you to make enough power to grenade the engine.
17th Nov, 2012 at 07:46:04pm
not sure if im right but ive always gone for the matching point. if the outlet on the head is (for eg) 38mm ID i will go for a 38mm ID tube collector, then match the collector to the turbo inlet. |
