| Home > Help Needed / General Tech Chat > oil feed pipe | |||||||
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
19th Nov, 2012 at 02:06:59pm
Hi all,
19th Nov, 2012 at 02:28:49pm
The hose is all the same -4, what you need to know is what thread is at the turbo end for the banjo fitting. As the block is the same, It was easier for me to make one up.
19th Nov, 2012 at 02:39:26pm
Oh ok, thats a big help, cheers for that Simon |
19th Nov, 2012 at 02:46:59pm
have a look at your turbo this may be worng but it says m11 for the Gt turbos,
19th Nov, 2012 at 03:22:08pm
Ok that looks good, it may be the one I need, but will not know untill back home from work to check the turbo. If this is the right one, then I just need a braided hose to join either ends right?
19th Nov, 2012 at 03:32:53pm
No mate its not hard to do,
19th Nov, 2012 at 04:00:00pm
Cool will do |
389 Posts Member #: 9751 Senior Member Derbyshire |
19th Nov, 2012 at 04:49:47pm
My gt17 is m12 x 1.25 pitch in the turbo oil feed, I 'thought' the gt15's are the same but not sure, I went to the local hydraulics place with turbo and asked them.
Edited by mossy2a on 19th Nov, 2012. |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
19th Nov, 2012 at 05:41:50pm
I went to my local pirtek with the turbo and banjo bolt for the block, got them to make me one. Was £35
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
1 Posts Member #: 11607 Junior Member |
9th Aug, 2017 at 10:56:39pm
eyh wsup guys new to the forum,,, finally stripped my motor done everything new,1275gt all paint done.will be puting it back together tomorrow.My question is i feel like doing turbo conversion my father in law is quite clued up on mechanical work he just want to know were to get oil feed from for turbo. |
10th Aug, 2017 at 07:51:20am
where the oil pressure switch is, fit a T peice and come off that On 28th Aug, 2011 Kean said:
