Home > General Chat > Cylinder head re guide (iron)
TurboMike1992
Member #: 9928
Hartley, Kent
After a 3 month painful wait from an engine rebuilder I finally got my cylinder head back after a re guide.
After having given him bronze guides, it came back with irons. Apparently he cocked up 2 of them so replaced them and cut the charge of cutting the seats in. Obviously I'm a little annoyed, but my question is are they okay to use? it's not like I'm running massive bananas, I'm set to 0.4 bar.
Cheers.
Low boosting for now.
Craigie-B
Member #: 9468
Wootton Bassett
he should have replaced the bronze with bronze, the iron ones are much cheaper arnt they?
Iron ones are half the price of the bronze ones, but will be fine for your boost.
TurboMike1992
Member #: 9928
Hartley, Kent
Cheers guys dad said to me it would be fine but he cut a tenner off the price too so it's not all bad.
Now do I stretch some stem seals over when re fitting? Or do I run without? I just don't want it to ploom out smoke again :'( lol
use the MPI seals, ( brown ones)
TurboMike1992
Member #: 9928
Hartley, Kent
Brilliant, cheers joe, I wanted to get those mra ones but doubt hell have any now days
I think you'll find the MPI ones fit better than the MRA ones anyway.
they are viton so will take the heat :)
The MRA ones fit well, but he went bust so they are NLA.
TurboMike1992
Member #: 9928
Hartley, Kent
Unfortunately so, he was a good man from what I hear, ill see if I can get hold of some mpi ones, can I get them on minispares etc?..
Use seals on inlets only.
Scudy23
Member #: 10087
Very wet south wales
Would that go for all heads Vegard ?
No, but for slightly modified engines which are run hard occationally I would. Especially on a turbo engine with iron exhaust guides.
Rick.SPI
Member #: 8027
He wasnt a good man, he was an absolute bellend.
ntm1275
Member #: 9395
Are the valves std material or stainless, as I thought you couldn't use stainless valves with iron guides
Could be wrong though
Scudy23
Member #: 10087
I was told last week that i couldnt run std valves with bronze guides, does that go for the other way around.
You can.
Correct.
I disagree. We ran them on the exhausts in the upside down skip at 25+ psi with no problem. We also put them on John's clubman with no issues (stopped it smoking like steam train too).
Edited by apbellamy on 21st Nov, 2012.
TurboMike1992
Member #: 9928
Hartley, Kent
They were iron guides before the re guide so I'm assuming that they are the original sodium filled ones, is there an easy way of telling them apart?!
