Home > Technical Chat > Starter issues
On my GT, I've fitted a Verto ultralite flywheel. This means when I turn the key, the starter jams. I wasn't aware that the flywheel was verto :)
What should I do with wiring. I do have the old starter solenoid fitted, and the wires aren't long enough for the intertia starter.
Have anyone got any smart solutions here??
I've never seen a inertia starter real close before.. :)
Edited by Vegard on 9th Jun, 2005.
depends on if you just want to get it up and running for now then fit a longer wire after.
if it is, then just leave the normal solenoid on the wing, length the starter wire that activates the solenoid and put it to the starter, then just put a both thick wires on the same post, and another one from the starter to the same post. just acts as a common post but does the job for now.
