| Home > General Chat > Crap headlight bulbs? | |||||||
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
26th Nov, 2012 at 12:46:58pm
The Corsa has just blown another dipped beam bulb at the weekend, and I've not long replaced the driver side dipped beam bulb as well (about 6 weeks ago). Now that the passenger side bulb has gone, I'm beginning to wonder if the bulbs are at fault, or whether I should start trying to diagnose a wiring fault?
26th Nov, 2012 at 01:09:37pm
Halfords bulbs ARE shit, last five seconds and are dull as hell, i will be replacing mine when i get paid for either 'rally' bulbs or some of the high intensity bulbs so i can see at night again. My pug used to use 90w130w bulbs said not for road use but they arent as bright as some oem zenon lights bloody good buy at £20 never had to change them in well over a year as well. The clio is on its 4th set of bulbs (got cheap ones, two sets from gaufords) and the current ones are dimmer than a unlit candel Drives
26th Nov, 2012 at 01:13:49pm
Just get main dealer bulbs. they are cheaper than halfrauds and will be much better quality On 11th Feb, 2015 robert said:
26th Nov, 2012 at 01:31:15pm
Once one goes, expect the others to go soon after. After all they will have all been on about the same length of time. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
26th Nov, 2012 at 01:32:56pm
Wiring is unlikely but it could be the alternator itself is putting out too high a voltage - a simple check.
26th Nov, 2012 at 01:46:29pm
Dont forget that when one headlight bulb goes the other burns brighter reducing its life Crystal Sound Audio said:
26th Nov, 2012 at 01:52:36pm
I picked up a pack of two Bosch bulbs in the end which I believe are the standard fitment for a Corsa, and so that they match each other for brightness.
26th Nov, 2012 at 01:53:43pm
On 26th Nov, 2012 wolfie said:
Dont forget that when one headlight bulb goes the other burns brighter reducing its life Fastest 998 mini in the world? 13.05 1/4 mile 106mph
26th Nov, 2012 at 02:34:36pm
I had similar issues, trying to find bulbs that were worth a crap (they are also a bit of a PITA to change). In the end, I went to a main dealer. He reached for the sylvania stuff on the counter, so I declined and asked for stuff in a box with the blue oval on it. They have to go rooting, but they did have them. I paid a little more, but 2 years later, I haven't changed them since. On 17th Nov, 2014 Tom Fenton said:
![]() 127 Posts Member #: 1871 Advanced Member Chesterfield, Derbyshire |
27th Nov, 2012 at 01:13:21pm
My Clio used to blow them every 2-3 months so bought 10 off ebay for the price of 1 from halfords |
27th Nov, 2012 at 07:01:13pm
Just buy a decent brand and they will last fine.
27th Nov, 2012 at 09:11:19pm
Buy quality bulbs! The cheaper ones don't seem to be manufactured for the environment they are used in. For example, take the old 100watt filament bulb in lamp in the back bedroom, switch it on and then shake it vigorously. It won't last 5 minutes. Thats because it was designed to be in a stationary installation. Those cheep headlight bulbs obviously don't like being jiggled about. On 26th Oct, 2004 TurboDave16v said:
27th Nov, 2012 at 09:27:04pm
Halfords standard bulbs are shit, You wanna get the 90% or 120% brighter they are buy one get one free
27th Nov, 2012 at 09:30:11pm
i bought some ring xeon max one for the mini. Meant to be 100% brighter, only 55/60w ones. Seem to do the job. |
![]() 55 Posts Member #: 9624 Advanced Member Seattle, WA USA |
27th Nov, 2012 at 10:10:00pm
I am going to do a HID retrofit with Morimoto mini D2S projectors and DDM Tunings HIDs. As I can't see the with lights on my clubman. I used Hella 500FF driving lights with the stock headlights on my cooper. It worked ok, but I don't have any other lights on my clubman. Will post pics any stuff when I get everything. 1991 mini cooper
