| Home > Help Needed / General Tech Chat > help, smokey engine, low power(update) | |||||||
![]() 384 Posts Member #: 4215 Senior Member |
26th Nov, 2012 at 09:47:38pm
hello everyone
Edited by c2_mad on 4th Dec, 2012. |
26th Nov, 2012 at 11:02:30pm
Clutch Problem: tell us the oil pressure, and what clutch it has?
26th Nov, 2012 at 11:39:30pm
Sounds like the gasket has gone between 2 and 3.
In the 13's at last!.. Just |
![]() 270 Posts Member #: 69 Senior Member Coventry |
26th Nov, 2012 at 11:44:47pm
sounds very poorly, compressions first, likly 2-3 blown, you have run it in with mineral oil in? |
27th Nov, 2012 at 12:00:14am
hello everyone
27th Nov, 2012 at 10:32:06am
Do a compression test, that will tell us alot, then will take it from there ? Is your cam timed in at 106 that cam the 266 is a little temprimental, on timing and is your valve clearance. Set @ 0.016"?
27th Nov, 2012 at 10:57:59am
hi benross
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
27th Nov, 2012 at 12:46:22pm
Mine makes the same smoke, but I dont have the low power issue and im also running a 266 On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
27th Nov, 2012 at 04:28:40pm
have you figured out what the problem with yours is?
Edited by c2_mad on 27th Nov, 2012. |
27th Nov, 2012 at 04:31:17pm
I put it down to the car not being tuned, my co2 readings are up at 5% for example On 10th Mar, 2012 theoneeyedlizard said:
27th Nov, 2012 at 04:55:04pm
the clutch can cause the engine to stall when you dont have any oil pressure. do you have a gauge? hot oil takes longer to suck up into the engine and circulate. mine did this. you should always make sure you have oil pressure before you use the clutch especially with the grey one. |
27th Nov, 2012 at 05:36:00pm
Did you run it in on synthetic oil ? A basic mineral oil is far better for this to allow the rings to bed. This could be your smoking issue. |
![]() 328 Posts Member #: 9107 Senior Member Devon |
27th Nov, 2012 at 06:16:36pm
Sounds like head gasket , also I would ask why the head gasket has gone, have you checked your mixture and ignition timing, what system are you running , ecu ? Or dizzy ?? . I had the same thing and ended up cracking my rings as the fueling and timing were out , went through 2 head gaskets before it happened so I can speak from experience . |
28th Nov, 2012 at 10:42:34am
hello everyone
Edited by c2_mad on 28th Nov, 2012. |
29th Nov, 2012 at 09:14:23pm
Oil pressure is ok at that, the compression should be 150psi in the head if it is lower Your head gasket is definitely gone there ! At worst case piston / rings too . My suggestion is to take the head off and pour fluid in each of the bores, you will then see if you have a broken ring or cracked piston . The standard needles often need to be profiled in order to obtain the right mixture , I would suggest that you may have been too lean ? One other thing to check is if the engine is breathing heavy through the 2 breathers either side of the engin as this is also a sign of broken rings .
Edited by redrat on 30th Nov, 2012. |
29th Nov, 2012 at 09:16:10pm
Let us know when you have results of the compression test, I do have a tester I can post to you if you need one. Fingers crossed for you mate Edited by redrat on 30th Nov, 2012. |
29th Nov, 2012 at 11:22:13pm
i would edit your last post incase someone else miss-reads it when using the search. |
30th Nov, 2012 at 01:01:12pm
On 29th Nov, 2012 Johnny said:
i would edit your last post incase someone else miss-reads it when using the search. Done :) didn't think about the search thing ! , someone could have been messing around for hours trying to get ridiculous oid pressure ! |
30th Nov, 2012 at 04:47:58pm
i would be really surprised if it was the rings, as i havent really given it any stick, i have hardly gone past 3000 rpm.
1st Dec, 2012 at 04:47:03pm
hello everyone
1st Dec, 2012 at 04:57:51pm
1st Dec, 2012 at 06:51:37pm
Well that Guy must be smoking mass!! weed stating that.
2nd Dec, 2012 at 08:23:15pm
hi guys
2nd Dec, 2012 at 10:17:17pm
have you checked the valve clearances yet?? and the compressions with oil in bores?
2nd Dec, 2012 at 11:18:41pm
From the number plate on the vid and the fact the poster refers to km's I would guess they are overseas. I run a supercharger and I don't care the TB is on the wrong side.
