Home > Beginners Tech > megajolt
kappa
Member #: 9854
Hounslow, Middlesex
Hi all,
I would just like some advise and before everyone asks me use the search bar, I have tried this but cannot find a section what parts are needed for the megajolt set-up.
Now basically the things I have purchased are:
Megajolt unit, loom plug, data cable and serial adaptor (its say its a TPS version, what is that and do i need anything for this?)
I have purchased a 36-1 trigger wheel
I am looking to purchase EDIS 4 coil pack and crank sensor inc. plugs very soon.
Now i would just like to find out is this all the thing I will need for the conversion or have i missed something out?
Also once I have all the parts, how do I fit this all in my car?
All help is really appreciated
Thanks
Bobby
I would say you need a MAP mega jolt NOT a TPS i had one like that for my webber.
have a good read here
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741
kappa
Member #: 9854
Hounslow, Middlesex
S**t does this mean I have just spent s**h load of money on megajolt unit, which I cannot use?
mercenary62
Member #: 9937
looks like it mate should be map mega jolt like madmk1 says
give em hell
redrat
Member #: 9107
Devon
Look at this link , bottom of the page tells you that for forced induction ( turbo) MAP is required . TPS is not sutable for turbo engines .
http://www.autosportlabs.net/Choosing_between_MAP_or_TPS
Sorry to sound blunt but it really pays to do your research first . You shouldn't have too much trouble selling your TPS ecu .
Also look on re trigger wheels website as they have useful links and sell all the bits required.
kappa
Member #: 9854
Hounslow, Middlesex
Damn it looks like it up for sale with the TPS megajolt unit
I know I will sound like a dick now but, As I have said before mate you need to read up on this stuff, and slow down.
Simon
lee.pb
Member #: 9199
Lancashire
You can modify the MJ to MAP, it's only 2x caps , 1 x resistor and of course MAP sensor.
All are can be purchased from farrnells for around £15.
http://www.autosportlabs.com/-c-1_21_28.html
Edited by lee.pb on 7th Dec, 2012.
kappa
Member #: 9854
Hounslow, Middlesex
That is ok mate, I managed to buy a MAP version one now, but thanks for the advise
