| Home > Help Needed / General Tech Chat > Need help with turbo'in my clubby | |||||||
47 Posts Member #: 124 Member |
22nd Dec, 2003 at 10:13:09pm
Rite then here we go! |
23rd Dec, 2003 at 08:51:07pm
You are as well turbocharging your existing engine - but keep it on low boost, you will at least sort out all the other little niggles that will happen, knowing that the base engine and box is sound (assuming it is???)
23rd Dec, 2003 at 10:26:26pm
hey
24th Dec, 2003 at 07:19:05pm
If your box is shot, then i'd advise you get hold of a good, low mileage 1275 metro engine/box and use that as the basis of your conversion.
![]() 323 Posts Member #: 41 Senior Member |
24th Dec, 2003 at 11:20:31pm
dave, the guy who rebuilt my box with jack knight gears advised me not to fit the central pick up pipe as this means that the box needs to be stripped and cleaned every few thousand miles, have you ever heard of this being the case?? A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
25th Dec, 2003 at 12:40:42pm
Ahh brill this is all gr8 help!
26th Dec, 2003 at 12:35:51am
can recomend the 266, pulls like a train from idle in 4th gear, very nice to drive day to day. turbo 16v k-series 11.9@118.9 :)
![]() 902 Posts Member #: 111 Post Whore Loughborough |
28th Dec, 2003 at 12:46:38am
hi t3 wty ( arron), I love my 286 cam cos when it hit cam at just under 3k rev the back end drop the front pull up then its party time, just like a good woman. but its a pain in traffic. good site isn't it! told u.
28th Dec, 2003 at 11:22:11pm
Cam profiles need more consideration than just the duration - the dynamic compression ratio is a major factor, and big cams need higher CR's to work effectivly.
