Home > Help Needed / General Tech Chat > Rear shock absorber issues
NB
Member #: 10097
Alright guys, wondered if anyone could shed some light on this for me.
I recently decided to lower the back of the mini as it was sitting way too high. I could have gone about it in a few different ways but I chose to machine down my cones down a bit, I ended up taking 12mm off for quite a significant drop. I did go quite low so now maybe very brutal speed bumps will be an issue, but that's not my problem. my problem is that now the cone is effectively too short, so on 'de-compression' it actually leaves the rubber donut or the knuckle joint (i cant be sure which). It wouldn't do this if the wheel wasnt able to droop down as much, so the shock is too long basically. Instant reaction is to shorten the shock but I have KYB gas-a-justs and I cant see how I'd open them up, let alone shorten them. I'm sure that once I got them open I could lower them though.
so basically, has anyone ever seen/heard of anything like this? if not, short of buying some new shorter shock absorbers, what are my options? please dont just say buy some hi los or coilovers *happy*
the ratio on the rear is 1 to 5 so if you remove 1mm of the trumpet you drop the car by 5mm on the front is 1 to 3 but....... i may have them the otherway around ??? some body confirm this ?
you have gone over the top ..... way over
i suggest you reinstate the ride heigh to original specifications in my opinion
especially with all those so called speed bumps the insane council highways planning department have implemented all over the dam bloody country.
anyway no amount of shockers and adjustment will componsate for correct ride heigh
NB
Member #: 10097
That's what I was going by, the 5 to 1 ratio.
The drop is about right, it sits at a nice height now. unfortunately you're probably right, i guess the cones can't be shortened by this much...
surely if i got hi-los and set them to the same height im at now i'd have the same issue?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Most damper suppliers list two types, the normal and the shortened. Buy the shorter ones and bobs your knob, ploblem solved.
http://www.twin-turbo.co.uk
NB
Member #: 10097
that would seem to be the case....so, anyone in the midlands got some shortened dampers I can get my hands on before the weekend? *happy*
edit: I'll have a crack at shortening these dampers first though
Edited by NB on 28th Nov, 2012.
Short dampers and Hi-LOs is your only sane option. Then adjust the Hi-LOs so there is a little preload at full travel.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I would have thought if you shorten the piston on its own, all that will happen is your shockers will bottom out, not good for you or the car.. Alan
Main Build
Upgrade to Turbo
I'd be very very careful cutting up dampers. Some of them are pressurised
Don't be silly. If it doesn't hit it now, shortening the damper rod won't make any differance to what it hits. Only the maximum droop.
I presume the plan is to cut the end off and re-weld it back on, say, 25mm shorter? Surely Sprockets idea to cut the cylinder is not on the cards?
Dampers are free, why bother cutting and welding. Welding a gas/oil filled damper could possibly qualify for a Darwin award.
http://minispares.com/product/Classic/Susp...classic/lowered damper.aspx|Back to search
I never suggested anything of the sort thankyou very much *tongue*
*wink*
NB
Member #: 10097
I had a look and chose not to attempt the above, there's no obvious way to go about dismantling them and anyone who's had a pair would know what i mean. If i were to shorten them there certainly wouldnt be any cutting and welding! by putting a spacer the appropriate side of the piston rod you could restrict the droop. well, this is the theory i've applied to many mountain bike forks anyway!
hi los and new dampers on their way *Clapping*
Good lad *Clapping*
nala56
Member #: 9661
If you shorten the damper piston in order to drop the car, then you shorten the travel of the shocker, is all was saying, where all learning here no need to get clever.. Alan
Edited by nala56 on 6th Dec, 2012.
Main Build
Upgrade to Turbo
