| Home > Help Needed / General Tech Chat > Dump valves | |||||||
31 Posts Member #: 330 Member Aberdeenshire |
10th Jun, 2005 at 01:03:23pm
Hi |
10th Jun, 2005 at 10:57:28pm
the best one to get is a adjustable piston type as you can adjust the amount dumped but if you dump to much you tons of lag between gear changes.
10th Jun, 2005 at 10:59:21pm
hi dave click on the link below on this subject discussed some time back
621 Posts Member #: 393 Post Whore Oulton Park |
11th Jun, 2005 at 10:46:11pm
one thing i will say is its weird how the dump value keep open not like that on other cars |
1171 Posts Member #: 107 Post Whore Sunny Sussex |
12th Jun, 2005 at 12:14:36pm
i thought the piston type's oil rings swell, read that somewhere, not suitable for a series or something
12th Jun, 2005 at 09:29:04pm
yep avonbar should have finished their bailey version with viton seals to cure this prob though |
13th Jun, 2005 at 08:05:40am
Thanks lads. So the bottom line appears to be that its more a flash harry device for making a noise than of any real practical use, is that correct or am I missreading the replies?
13th Jun, 2005 at 09:00:47am
i would use a standard butterfly from another 1 3/4 hif.
13th Jun, 2005 at 09:43:43am
Sorry I don't understand the bit about the butterfly. I was meaning the standard valve in the plenum. Can you explain the about the butterfly please. Sorry to be dumb re this but I only learning! |
14th Jun, 2005 at 09:41:15pm
sorry misread your question, ive been told to keep the plenums as they are if not they have a tendancy to fuck the carb settings up to all over the place.
