| Home > Beginners Tech > Megajolt what to buy? | |||||||
53 Posts Member #: 9238 Advanced Member |
1st Dec, 2012 at 11:48:43pm
hello forgive if I understand well am Spanish and use google translator
2nd Dec, 2012 at 12:45:21am
and also where I could buy at the best price. |
![]() 328 Posts Member #: 9107 Senior Member Devon |
2nd Dec, 2012 at 08:40:29am
Try typing megajolt in to the search forum on here to find out .
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
2nd Dec, 2012 at 10:35:03am
have a look at nodiz too:)
internationally known as "big" swede |
2nd Dec, 2012 at 05:53:46pm
Hi I have used the search but as I use a translator just to clarify which is what I need ..... |
2nd Dec, 2012 at 06:25:41pm
Not the cheapest way to get everything needed, but it shows you what you need.
2nd Dec, 2012 at 08:30:07pm
Hi all I need I have it clear, what is not to model megajolt I have to buy as there are various models, and also where to buy it as cheap as possible |
3rd Dec, 2012 at 08:44:50am
There are 2 types for the a series . MAP and TPS . If you are using a turbo you need the MAP type.
6th Dec, 2012 at 09:35:31pm
Does this I would be worth?
7th Dec, 2012 at 08:21:33am
It seems like a lot to pay all at once, but its a sure way to get all the parts needed and from a reliable supplier. |
7th Dec, 2012 at 11:14:51am
That's trigger wheels selling in eBay . If you buy direct from their website it's cheaper . |
82 Posts Member #: 9772 Advanced Member Sheffield |
12th Mar, 2013 at 05:31:24pm
Does everybody agree that this is the best system for a 1380 carb turbo set up or are there other options? |
12th Mar, 2013 at 05:35:16pm
On 12th Mar, 2013 Jack2eaton said:
Does everybody agree that his is the best system for a 1380 carb turbo set up or are there other options? No as somebody recommended looking at nodiz.
I would, however, say it's the most tried and tested mapped ignition in use on this forum. On 11th Feb, 2015 robert said:
