Home > For Sale > 1330 Fast Road Engine
adcyork
Member #: 6807
York
Up for sale is my 1330 fast road engine as it came out of the car today - £650 OVNO
Located in Coventry, CV5
Covered 6000 miles with four oil and filter changes since going through a full rebuild.
Spec when built:
Engine
1330cc
10.7:1 Compression ratio
New +60thou 21253 AE pistons
Stage 1 Ported and rebuilt unleaded 12g940 head, Recut valve seats, New minispares 160lb double valve springs,
Block acid dipped with new gallery and core plugs
Reground CAM6232 crank - groundto 10 thou big ends, 10 thou mains - New vandervell bearings
New cam bearings
Rebushed primary gear honed to correct clearance for fast road with correctly shimmed drop gears
Minispares centre main strap.
New Swiftune SW5 camshaft, vernier timing gear, followers, oil pump.
New ARP big end bolts
New high capacity, cast impellor, water pump
Braided block to filter pipe with (pre-bearing) oil temp take off
Block and gearbox flange drilled and tapped for 5/16UNF fixings
Gearbox/Clutch
A+ casing
3.105:1 Final drive
Centre oil pick up pipe
New minispares uprated diff pin and bushed planet wheels
New second gear
New 1st/2nd selector fork
New genuine baulk rings.
New bearings throughout
New AP verto clutch
New clutch arm
(Megajolt coil bracket not included)
A few pics of the engine as it came out, followed by a few during the engine build:
Thanks
Andy
Bargain! Much better than the tat you get off eBay.
MarkGTT
Member #: 1194
Shropshire.
Did you have this on a rolling road? If so what one and what did it make?
Thanks
adcyork
Member #: 6807
York
Cheers John, I did put every painstaking detail into this build and everything was done correctly.
Mark, the engine was tuned after a 500 mile run in period at a MBE race engines in Lincoln.
It made 62bhp at the wheels, 83 at the flywheel. Plonk a stage three head on it and it should be good for around 100bhp at the fly.
Edited by adcyork on 3rd Dec, 2012.
adcyork
Member #: 6807
York
BUMP
I have let a mate know about this as its just what he is looking for.
Mate can you pm me your mob nub as my mate said he will have this! and will call up with the cash tomorrow.
Edited by madmk1 on 5th Dec, 2012.
adcyork
Member #: 6807
York
Pm'd
shellspeed
Member #: 9580
Surrey
Be 162 at the wheels if you paint it red *happy*
adcyork
Member #: 6807
York
Damn it, I knew I'd forgotten something. I could easily have doubled both hp and price if only I'd given it a lick of red paint...
daveydavey
Member #: 10031
so...that meen you seeing red now?.......ooowwwwww...best climb in a hole
adcyork
Member #: 6807
York
SOLD!
Craigie-B
Member #: 9468
Wootton Bassett
Have you guys got collection and everything sorted? Im based in coventry and can take it to wootton bassett if thats any help for you
adcyork
Member #: 6807
York
Thanks for the offer Craig!
Its going down to Kent unfortunately but thanks again.
Craigie-B
Member #: 9468
Wootton Bassett
no worries, all the best!
