Home > General Chat > front subframe
Mark1
Member #: 10200
Cambridge England
Whats the best front subframe to use when turbo charging a standard mini?
t@z
Member #: 452
Chester, UK
the one in the car?
www.twitter.com/lilpinkiy
mercenary62
Member #: 9937
just use std subframe or lighten it with a drill and holesaw
give em hell
A red one. It will give you more BHP!
redrat
Member #: 9107
Devon
*happy*
Will be painting mine red now !!
on a serious note, the standard frame will do.
Having said all that, in the earlier days, it was common practice to triangulate the frame and solid mount the rear section to the bulkhead to make up for the formation of the bulkhead box. If I recall correctly, Avonbar used to supply the kit of metal plate needed to do the job.
i've seen very few cars with this mod though
Simon
Member #: 1865
Norwich, Norfolk
Your thinking of the engine, I thought the subframe had to be blue
Amp
Member #: 7856
Also on a serious note, if you search on here, I think it is the auto and later MPI subframe moved the engine backwards 12mm or so, which may help/hinder dependent on your application?
Do the search though if this is relevant as my numbers are most likely off!
Mine does
Mine too. It makes changing the steering rack a complete twat.
Didn't the later frames MPI etc moved the engine forwards?
Auto frames are wider and need adaptors to put a manual engine in.
Late frames (HIF carbed cars onwards) move the engine forward 10-12mm. Auto frames drop the engine down lower if you have bracketry to convert the engine mounts.
Has got nothing to do with turbos, but this could be useful...
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=174403
shellspeed
Member #: 9580
Surrey
SPI and as Will says MPI frames have moved the engine forward 10-15mm. Good news at the back but even less room down the front!
They moved the engines forward to get the HIF38/44 carbs in as they are deeper than the HS carbs. I had to 'adjust' the bulkhead in my old clubman to get a HIF38 in there.
Amp
Member #: 7856
Ah, apologies I stand corrected, I knew it was one way but forwards doesn't really help matters (unless you already have an MPI/SPI one and need more front room!)
Personally I prefer the earlier (twin bolt towers) type.
(a) it's solidly mounted by design, and,
(b) the rear legs attach to a much stronger part of the floor.
I've also strengthened the tie bar mounts as mentioned above because I too have had one fail on a standard car.
with all this said, basically, you can use the frame that is already in the car..........
