| Home > General Chat > Tough cookie | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
7th Dec, 2012 at 10:07:07pm
You can say a lot about Ken Block... But he doesn't bail out quickly...
Dazed and Confused.... |
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
7th Dec, 2012 at 10:31:52pm
muck fee thats mental give em hell |
7th Dec, 2012 at 10:37:05pm
Everything is fire retardant, the fact that it never flared up fast shows this, and its likely the radiant heat from the exhaust, especially if its got a cat, that's set fire to the wiring under the dash display thing.
8th Dec, 2012 at 09:17:50am
Maybe exhaust got displaced after the jump..
8th Dec, 2012 at 10:45:11am
Dont know but that tail pipe was glowing red most of the way around, i would have thaught that he would have had a plumbed in extinguisher system? I run a supercharger and I don't care the TB is on the wrong side.
82 Posts Member #: 1278 Advanced Member Bedfordshire |
8th Dec, 2012 at 11:26:51am
the reason they glow red now is because the cat is usually right at the back of the system so its less restrictive, so the glow is just the cat as they run that hot to work |
8th Dec, 2012 at 11:47:46am
On 8th Dec, 2012 Yo-Han said:
Just to display my obvious ignorance; does a cat get hotter than a 'normal' exhaust? The internals most definately do, they get VERY hot as the "catalyst" is essentially inducing further combustion of the un-burnt bits of the exhaust gas. The outside will be down to how well it's designed (insulation, heat shields etc.) and manufacturers cut corners :) Schrödinger's cat - so which one am I ??? |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
8th Dec, 2012 at 12:48:21pm
Not sure if the rally cross cars are anything like the Fiesta world rally cars but they have the cats just before the back box David. |
8th Dec, 2012 at 01:19:18pm
Tough cookie no idiot yes!
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
8th Dec, 2012 at 05:13:04pm
i'm not saying i wouldnt brick it but its his job n he is probably used to the odd fire n knows enough to have confidence in that its wont just go ka-boom |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
8th Dec, 2012 at 05:30:28pm
What sprocket said about the fire retardent stuff, Ive seen a road car catch fire and within 10 mins the car and the garage and half the house was burnt down On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
