| Home > Help Needed / General Tech Chat > Manifold gasket | |||||||
8th Dec, 2012 at 11:49:51am
Just stripped out the manifolds and turbo as I have had an irritating small leak, which I suspected was the turbo to manifold again.
8th Dec, 2012 at 11:58:07am
are all the ports level on the manifold.
8th Dec, 2012 at 12:12:36pm
might be worth having a light surface grind on your manifold, i have always used a turbo gasket and never had a problem http://www.minispares.com/product/Classic/...k%20to%20search Crystal Sound Audio said:
8th Dec, 2012 at 12:43:14pm
There is a little distortion Andy, but no worse than any of my manifolds - Ill dress the faces up, just to be sure.
8th Dec, 2012 at 01:12:27pm
we never had any bother with the injection one as long as we got everything tightened properly On 11th Feb, 2015 robert said:
8th Dec, 2012 at 01:43:45pm
Ive been fine with the std competiton one without the rings,
![]() 384 Posts Member #: 4215 Senior Member |
8th Dec, 2012 at 01:59:20pm
i have used the mpi one with no problem at all |
8th Dec, 2012 at 02:05:35pm
I moved to the mpi one after I had the same sort of thing happen to me. Now it's fine. I just give every thing a good key up first. I have started posting on Instagram also my name on there is turbomk1golf
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
8th Dec, 2012 at 03:19:56pm
Im using the metal injection type one, told somerford what I was after and they said that would be a good shout On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
8th Dec, 2012 at 05:19:30pm
Thanks everyone -- MPi gaskets on the way. |
