Home > Technical Chat > actuator on eaton m45
Rammie2000
Member #: 10190
belgium
where does a actuator on a eaton charger go? and does there exist a "in line" sort of actuator? (i mean a actuator that is located between the hoses that go from a charger to the plenum chamber)
i'm looking for all parts to build my blow trough supercharged engine.
what i have so far
is a 1340 cc engine with cast pistons with a 6.5 cc dish. ( to make compression go lower i have a old long-man cylinder head with some pitting witch i can adapt to hold more cc).
i will use a standard gearbox with straight cut drop gears 3.1 final drive and 4 pin diff (think that will hold up the power). i also have a water cooled (heated) inlet manifold that i will drill holes in an ad 2 vacuum taps, 1 for the dump valve and 1 for a actuator. (or do i just tap in 1 and split it up with a T piece? )
i am looking for
a reconditioned plenum chamber from a metro turbo on ebay. ( its about 75 pound now think thats a fair price?)
if i understand correct the dump valve go's on the top left outlet from the plenum camber (what dump valve is best to use?)
will be sourcing a second or third generation charger.
i will adapt the original hiff 44 to turbo spec but cant find how on the forum (maybe i use the wrong words to look it up... i used : hiff 44 na to turbo and so on) but i thinck that if i close the top with a ring and make the float-bowl bigger with a spacer plate and put a return-feed pipe on to where the overflow sits on a Na hiff 44 i will be there?
am i missing a peace here? *oh well*
The M45s on a bini have a re-cirq valve rather than an actuator.
How do you recondition a plenum chamber? slap some paint on it? £75 is expensive.
Rammie2000
Member #: 10190
belgium
oh really? it are some i found on e bay
http://www.ebay.co.uk/sch/i.html?_trksid=p...cat=0&_from=R40
so if that's expensive than what price should i look at?
hmmm recerq valve... i only found chargers for sale who have nothing bolted on them... so that's why i thought (hoped) there exist some kind of actuator that sits "in line" ( dont know how to explain it correct but lets say... cut a tube stick it in between and continue tube ... or sated different ... works like a dump-valve but one that does not let all pressure go)
re-cirq valves go in the boost hoses between the engine and charger.
You are looking on ebay at the over inflated prices. Those ones are still for sale for good reason. Stick a wanted add on here and you will get a more competitively priced one.
Rammie2000
Member #: 10190
belgium
daim your good. thought i will be looking for another week for those answers...
thanks allot!!
will put an ad the minute my wife stops looking angry about the last 20 things i was not going to buy bit bought anyway (came home with a new race bike last week that i forgot to tell her.... *hehe!* *hehe!* *hehe!*
Rammie2000
Member #: 10190
belgium
instead of a re cirq valve i was thinking to use a dumpvalve who can be set at a max pressure ( i thought if a set it at for example 10 psi and the charger go's up to 12 psi it wil just dump 2 psi ) is dis a do or a dont? happy end off the world everyone
Andy500
Member #: 2443
Cheshire
The re-circ is part of the casting, if you flip an m45 over and look at the outlet then you will see there are two ports, one each side of the big hole in the middle which allows air to recirc back up the outside of the screws/impelors.
Andy500
Member #: 2443
Cheshire
Why waste all that energy compressing to 12 psi just to 'dump' it. You want to keep the m45 below 10 psi as after that your just making heat!
