Home > Help Needed / General Tech Chat > not sure what to do
wng691s clubby
Member #: 9252
Cleethorpes
hi guys nearly there,car starts ok now but is runnig really rich at idle 10 on afr and really lumpy have to rest foot on accelerator for it to tick over nice iv tried adjust the mixure screw but not made any difference. fuel pressure is 3.5 psi im using the vans map. any tips to try
Done now needs redoing lol
Mike-998
Member #: 9774
Buckinghamshire
Not sure if the rich afr rules this out but I had a lumpy idle on mine, the cause was an air leak in the end. Have you tried brake cleaner on similar on all the joins?
wng691s clubby
Member #: 9252
Cleethorpes
il give that a try mike. i guess you mean intercooler ect
What sort of RPM is it ticking over at?
What ignition control do you have, have you tried advancing the timing at tickover?
The vans map is/was quite aggressive at low rpm. this caused Craig some running problems at low revs
wng691s clubby
Member #: 9252
Cleethorpes
im not sure off the top of my head il go check now
by ignition control do you mean megajolt? im using version 3.0 with andy and johns van map
havent tryied advancing timing as im just working out how to use megajolt software
wng691s clubby
Member #: 9252
Cleethorpes
sound about right for you two
wng691s clubby
Member #: 9252
Cleethorpes
just been out to the car plugged in the laptop and its ticking over at 1200 rpm it didnt seem lumpy this time tho but it is warm from this morning still. im guessing to change the tickover i need to change the advance? is this correct?
it's a balancing act mate.
advance/mixture/throttle idle screw position.
i believe the standard static timing of a metro turbo was 7 degrees @ 1500rpm with a distributor.
You could try setting the idle advance to about 8-10 degrees then adjust the idle screw and mixture screw. what needle do you have in there?
wng691s clubby
Member #: 9252
Cleethorpes
the one that came with your carb. at least it runs and no smoke. think il be buying a bdd and start from the begining. the needle thats in has been profiled and the mixture screw was all the way in before i adjust to get it to start.
I've emailed you some maps to get you started, try the 22 degree one. It should be pretty safe. Also it would be a good idea to get a BDD in there as a starting point.
wng691s clubby
Member #: 9252
Cleethorpes
cheers john i was just looking at the stanard metro turbo map and it advance is 15 degrees at 1200 rpm
Give it a go.
wng691s clubby
Member #: 9252
Cleethorpes
just ordered a new needle to going to wait till that arrives
Check the cold start mechanism on the carb is not leaking internally, not uncommon.
Make sure the engine fully warmed up. Set idle advance at 15 degrees and then tune idle air and AFR to ~14.7 to get to your idle rpm. now adjust the cold start linkage as per the book
Edited by Sprocket on 10th Dec, 2012.
wng691s clubby
Member #: 9252
Cleethorpes
i shall look into this
The fault here is not the vans map, on idle you must find the the fault.
IMO as the lads say that map is very aggressive, I would definitely. Adjust any timing figures over 30 degrees. To 30 and any boost @ 7 and above 7 pounds to 10 pounds drop to 28, and anything above 10 pounds to 13 drop 24 degrees And anything above 10 drop to 22 and take it from there,
This is born out of experience, on the rolling road and a smashed piston
There are no two engines the same, better to be safe that it all end in tears.
