Home > Help Needed / General Tech Chat > SC engine knocking
Nick warwick
Member #: 8926
Sheffield
My SC has developed a nasty knocking, it seems to be coming from the supercharger.
Could be the SC bearing?
Quick video
http://youtu.be/C8gPAha6SCk
Thanks
Nick
Edited by Nick warwick on 10th Dec, 2012.
wng691s clubby
Member #: 9252
Cleethorpes
sounds like the scrolls are rubbing
Done now needs redoing lol
nick , it may be the coupling ,i had to replace a db7 eaton supercharger ,the thing was worn out and scored , but also ,had a knocking noice that was caused by play in the coupling.
the blower i used to replace it with , off a ford thunderbird ,had a different design of coupling that was much better and quiet .
Nick warwick
Member #: 8926
Sheffield
Thanks, just googled eaton 45 coupler and got it page.
http://www.superchargersonline.com/index.p...page=page&id=57
Nick warwick
Member #: 8926
Sheffield
SC gears with the nose off knocking
http://youtu.be/cQ4iJTO4GvU
Chalkie
Member #: 9764
Northamptonshire.
thats the supercharger knocking for sure its the scrolls knocking bearings properly warn
Nick warwick
Member #: 8926
Sheffield
Anyone replaced these bearings before?
checked the coupler and mines got no play but if you spin the gears by hand you can hear the knock like in the second video.
Chalkie
Member #: 9764
Northamptonshire.
I never have but been told that oil is highly carlsagenic
Nick warwick
Member #: 8926
Sheffield
Hopefully it's not
If the bearings have failed will the casing and scrolls not be fucked?
