Home > Help Needed / General Tech Chat > fuel pressure cant get below 5 psi
charlieb150
Member #: 9931
brighton
hi all i was trying to set up my fuel pressure reg but could not get fuel pressure below 5 so i changed my return line to the tank as the rubber had gone hard and shrunk so replaced with 8mm hose but still couldnt get it below 5 psi. also is this linked to this whilst drivng and car starts to come on boost it hesitates and holds back and also if i rev it whislt standing still it seems rough but it is sparking etc
by the way i have tryed the tee piece trick
thanks charlie
Replace the regulatory my guess its goosed or weaken the spring inside it,
is your fueling spot on? Have you a lambda gauge ? and what timing are you running megajolt or original dizzy? . . . Prey tell us more
charlieb150
Member #: 9931
brighton
im running standard turbo hif 44 with bdd needle with co @4.5 at idle :engine spec of slark stage 3 head, minispares roller rockers,minispeed turbo cam @110 deg, forged omegas lightend balance conrods, centre main strap, lightend verto flywheel. and im running std tr=urbo ducillier dizzy, running 4psi boost
charlieb150
Member #: 9931
brighton
oh and it 1293 just built
Buy your self an AEM lambda gauge, from e bay they are cheap is now!, then you will know where you are.
After sorting the fuel pressure out go to the rolling road and get it set up CORRECTLY for the maximum. Boost your engine is built for ie compression there is no excuse, that dizzy has a little too much advance @ 28 degrees Max advanced to safegaurd your engine if you want to run boost levels of 12 pounds or over it all depends on many factors though but. .... its just general. Advise, your rolling. Road. Is your best friend
charlieb150
Member #: 9931
brighton
ok thanks benross its going its to mini motorsport in shoreham on thursday for them to have a play with it as im busy with work at the minute and dont have much more than more than 30mins a evening lol ive managed to get the compression down to 8.1-1 so the plenty of boost to play with and will be going mega jolt soon thanks will get the rolling road sorted
Let us all know what power and torque it produces get a graph of it,
And don't forget to fill the tank with high octain fuel for a safegaurd befor you hand it over to the gibbons.......lol
charlieb150
Member #: 9931
brighton
Yeah I will do I should be doing a power run mid January so will keep posted
Johnny
Member #: 6926
Accrington
am i right in thinking if its tuned to higher octance fuel you should keep using it. to avoid det?
charlieb150
Member #: 9931
brighton
i think so but im only a apprentice for ford lol well level 3
jakejakejake1
Member #: 10010
Northants
I would say get it tuned/ rolling roaded on whatever your standard fuel is.
But if you are purely going for a power run with no changes to be made then run high octane - probably won't help with power but will be safer - which I think is what Steve means
5psi isn't a problem. As long as the pressure is not breaking open the needle walve in the float bowl it's not a problem.
The FPR does not affect the fuel pressure on boost. All it does is in crease the feed pressure of the fuel to continue to fill the folat bowl up while under boost. It needs to do this as the float bowl becomes pressurised when boost is made.
Your car will run fine (even with boost) with the fuel pump turned off (until the float bowl empties that is).
Whatever your running issues are it's unlikely to be FPR related, as long as it's not breaking open the needle valve.
check the diaphragm in the fpr ,,,look closely for little splits .
charlieb150
Member #: 9931
brighton
hi all manged to take apart and cleat the fpr but that did not fix to running problems, i found it to be because of the dashpot spring being to weak so changed that and now is sorted thanks for the help
Mr Joshua
Member #: 1954
Luton Bedfordshire
Right just finished reading tbis thread. You need to fit the fuel pump resistor to the fuel pump! I do not know if you can still get your hands on the original part so I will get you the exact spec of the one fitted to my car
I am betting your running an original metro turbo fuel pump or an original rover SD1 Maestro Efi or turbo fuel pump and that will be why your having this issue.
Early Metro turbos were equipped with these resistors and if you check the wiring diagram you will see this identified.
I have one fitted for this very reason, also it also stops the pump from cavitating and stalling which was a massive issue for me.
Own the day
charlieb150
Member #: 9931
brighton
ok thank you
