| Home > Help Needed / General Tech Chat > help on dizzy/megajolt | |||||||
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
13th Dec, 2012 at 12:40:35pm
Hi all,
13th Dec, 2012 at 12:56:46pm
I fitted megajolt within a day. If you have the diagrams its not hard... |
13th Dec, 2012 at 12:58:09pm
Plus the first trip that i would be taking would be to a rolling road to have it set up. Why would you do it twice? |
13th Dec, 2012 at 01:00:41pm
unfortunatly I do not have any diagrams, as i bought a used unit, does anyone have a copy that they can email me |
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
13th Dec, 2012 at 01:09:48pm
bobby
Edited by t@z on 13th Dec, 2012. |
13th Dec, 2012 at 01:27:47pm
For the crank sensor, get Tom Fenton to machine your damper and supply a sensor bracket. They are fit and forget items then. On 11th Feb, 2015 robert said:
13th Dec, 2012 at 02:19:18pm
T@z that is exactly what I needed, thanks a lot for that, that is a big help. Cheers |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
13th Dec, 2012 at 07:00:17pm
MED do a nice trigger wheel and sensor bracket you still need to cut a tooth off tho if you get one Done now needs redoing lol |
13th Dec, 2012 at 07:46:56pm
Thanks for the help guy, I already have the trigger wheel, one that is machined into the original pulley, the only thing I do need now is the VR Sensor and Sensor Bracket |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
13th Dec, 2012 at 07:52:23pm
On 13th Dec, 2012 apbellamy said:
For the crank sensor, get Tom Fenton to machine your damper and supply a sensor bracket. They are fit and forget items then. even contacted Tom for a pulley and bracket, its an easier way of getting the VR sensor and trigger wheel in the right spot instead of working out 9 teeth the missing one at TDC on a home made bracket. there's not much too the wiring either, the main task with mine will be converting MJ from TPS to MAP which i have ordered the parts. hopefully going to make a loom over xmas can do a post if required. Brief walk through below: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741 What the mind can conceive the mini can achieve
13th Dec, 2012 at 07:54:57pm
sorry for hi-jacking Kappa, but what screened cable have you guys used for the VR sensor, looked on trigger-wheels and they want £10 for 5 meters but its the £10 postage i'm not willing to pay What the mind can conceive the mini can achieve
13th Dec, 2012 at 08:15:53pm
Job done!
13th Dec, 2012 at 08:18:45pm
On 13th Dec, 2012 madmk1 said:
Job done! http://www.maplin.co.uk/stereo-double-shie...one-cable-98022 cheers madmk1 just wanted to check, hopefully get loom made over xmas. What the mind can conceive the mini can achieve
13th Dec, 2012 at 08:20:32pm
Have a look for that sort of thing mate, thats the full on stuff in that link. I have started posting on Instagram also my name on there is turbomk1golf
13th Dec, 2012 at 08:29:29pm
Have a look for that sort of thing mate, thats the full on stuff in that link. i'll go for the full on stuff, got a trip to RS in morning to pick up bits to convert MJ from TPS to MAP so will call in maplin and pick a couple of meters up. I assume you can also use it for PIP and SAW connections between MJ and EDIS 4. What the mind can conceive the mini can achieve
13th Dec, 2012 at 08:32:15pm
what I mean is I think there is some sort of stuff like sting inside it. I have started posting on Instagram also my name on there is turbomk1golf
13th Dec, 2012 at 09:32:35pm
I used the cable from the link above recently when I rewired my engine. It does have string in it but it wasn't a issue :) |
13th Dec, 2012 at 10:18:37pm
Hi Lee.pb that will be good to have a that post, thanks a lot for that advise
On 13th Dec, 2012 lee.pb said:
Kappa, in in the same boat with regards to MJ, there's lots of use full information on autosportslabs website and forum. i must of spent many nights now reading up on it and think i've got it sorted. On 13th Dec, 2012 apbellamy said:
For the crank sensor, get Tom Fenton to machine your damper and supply a sensor bracket. They are fit and forget items then. even contacted Tom for a pulley and bracket, its an easier way of getting the VR sensor and trigger wheel in the right spot instead of working out 9 teeth the missing one at TDC on a home made bracket. there's not much too the wiring either, the main task with mine will be converting MJ from TPS to MAP which i have ordered the parts. hopefully going to make a loom over xmas can do a post if required. Brief walk through below: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741 |
, the only thing I need is the VR sensor and bracket now. The only problem I have is how to set this all up, as I have no clue.
