Home > General Chat > A/r, trim, and maps ?!?
hello
please can someone explain to me what A/r, trim, and maps are, and how do you work them out,
preferably in simple terms to start with, then i may fire off some more technical questions
thanks
dan
Member #: 93
nic, a/r is covered in this section
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3237
trim is another ration, which is the the inducer squared, divided by the exducer squared (where the inducer is the smaller diameter of the radial compressor wheel, and the exducer is the larger diameter of the radial compressor wheel)
maps show the area in which the compressor wheel performs best, i did have a good link somewhere which allowed you to calculate etc what size turbo you need
some other people may be able to offer a more concise answer..
