| Home > Help Needed / General Tech Chat > Proposed spec | |||||||
269 Posts Member #: 396 Senior Member sheffield/rotherham |
13th Jun, 2005 at 02:59:58am
block bored 20cc Edited by lanxter on 13th Jun, 2005. speed is the best rush i have ever had!!!
13th Jun, 2005 at 09:03:38am
how long is a piece of string all depends on what boost you want to run.
13th Jun, 2005 at 09:32:27am
IMHO forget the phaze 3 cam
13th Jun, 2005 at 01:08:12pm
rite cheers lads, where would i get a tam1521 head gasket from?
13th Jun, 2005 at 01:15:06pm
std crank is fine @ 25 psi, what do you call high boost? On 15th May, 2009 TurboDave said:
13th Jun, 2005 at 03:24:58pm
around 20-30psi lol tbh i dint think standard crank would hold 25psi. but ive never had 1 so u know more than me lol. standard crank it is then speed is the best rush i have ever had!!!
13th Jun, 2005 at 03:29:35pm
just balance it and it will be fine On 15th May, 2009 TurboDave said:
13th Jun, 2005 at 09:04:03pm
Similar spec to me |
13th Jun, 2005 at 09:14:14pm
Mine will be
14th Jun, 2005 at 12:27:33am
cheers lad so round 150 bananas and running around 20psi of boost, sounds good enough to me speed is the best rush i have ever had!!!
14th Jun, 2005 at 06:14:01pm
im hoping to run a good chunk less than 20 to get 150 bananas, hopefully around 15-18 but only a RR session will see.
14th Jun, 2005 at 08:21:39pm
with that configuration chaps and set up correcctley
14th Jun, 2005 at 09:11:34pm
spot on ben, only time shall see tho i suppose speed is the best rush i have ever had!!!
