| Home > Help Needed / General Tech Chat > Run thermostat in a dry deck setup? | |||||||
![]() 296 Posts Member #: 9117 Senior Member Northampton |
16th Dec, 2012 at 02:42:39pm
Do i run thermostat in a dry deck setup? Due to different flow rates? Confessed addiction to everything mini |
16th Dec, 2012 at 03:04:11pm
yes. the flow rate is the same, it's just the coolant is taking a different path through the engine On 11th Feb, 2015 robert said:
16th Dec, 2012 at 03:05:08pm
16th Dec, 2012 at 03:25:52pm
Thanks for the replys, I have no bypass does it require drilling? Confessed addiction to everything mini |
16th Dec, 2012 at 03:50:37pm
unless your not running a heater( and have it blanked...) I'd put a small hole in there... jut a couple of mm just to let air bleed through, unless it already has the hole with jiggle pin On 28th Aug, 2011 Kean said:
16th Dec, 2012 at 04:03:40pm
you need a bypass of some sort ( ie small hole in the thermo)
Yes i moved to the darkside |
16th Dec, 2012 at 04:06:01pm
Just running dry deck kit not internal heater and std thermo at mo not yet driven on road so only run up in garage have had timing set etc going for mot soon just wanted to be on top of any potential issues should I have one Confessed addiction to everything mini |
16th Dec, 2012 at 04:40:04pm
Just put the water pump to head bypass hose in. The hole in the head is blacked of with a big screw. On 11th Feb, 2015 robert said:
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
16th Dec, 2012 at 04:44:28pm
why would you need the head to pump bypass hose??? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
16th Dec, 2012 at 04:53:11pm
to allow some coolant circulation if you have no heater etc. On 11th Feb, 2015 robert said:
16th Dec, 2012 at 05:02:03pm
ahh okay
17th Dec, 2012 at 10:10:22am
So in theory if you wasn't running a thermostat you would need the restriction plate.... But if you too the internals out of the std thermostat that would regulate the flow to be the same? ?? Confessed addiction to everything mini |
17th Dec, 2012 at 10:19:40am
The thermostat doesn't regulate flow, it opens and closes based on temperature.
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
7th Apr, 2014 at 06:53:37am
Ok so bringing up an old thread.
BHP sells engines, but Torque wins races! |
7th Apr, 2014 at 08:44:12am
I have no problem with the hose, the problem arises when people fit those shit concertina type ones, fit a kevlar or silicone bypass hose cut to the right length and using good clamps and you'll be fine bud On 26th Jan, 2012 Tom Fenton said:
